Large Fillet radius
I want to fillet two perpendicular lines with a radius that is larger than one of the lines is in length. It keeps displaying *invalid*. Is there any other way of doing this task?
will
Try using the CIRCLE command. When prompted use tan>tan>radius. Just trim off the excess lines afterward.
In AutoCAD (2005), start the Fillet command, enter your Radius and change the Mode to NoTrim:
  Quote
Command: f FILLET
Current settings: Mode = TRIM, Radius = 999
Select first object or [Polyline/Radius/Trim/mUltiple]: r Specify fillet radius
: Specify second point:
Select second object:
Radius is too large
*Invalid*
Command: FILLET
Select first object or [Polyline/Radius/Trim/mUltiple]: t
Enter Trim mode option [Trim/No trim] : N
Select second object: (OK, NO problem)
