aps Posted September 16, 2014 Share Posted September 16, 2014 Hi! First of all sorry for my poor english. I'm total beginner in AutoLISP, I work mostly with GIS software and data, but i have to manage the following problem. I've recieved a big DWG file which is containing around 30000 entities with various entity types and several layers. Everything is in a custom local coordinate system, and I have to transform it into an other coordinate system. I only have the transformation equations, so I create my first AutoLISP file based on codes I've found on this and other forums: (defun c:customtransform() (if (setq ss (ssget "_:L")) (repeat (setq i (sslength ss)) (setq entitylist (entget (ssname ss (setq i (1- i))))) (setq obj (ssname ss i)) (setq new nil) (repeat (setq j (length entitylist)) (if (= 10 (car (nth (setq j (1- j)) entitylist))) (progn (setq x (cadr (nth j entitylist)) y (caddr (nth j entitylist)) ) (setq y (+ (+ (+ 0 332134.109) (* 0.40008331 x)) (* 0.59595102 y))) (setq x (+ (+ (+ 0 1087.012) (* 0.59595102 x)) (* -0.40008331 y))) (setq new (cons (list 10 x y) new)) ) (setq new (cons (nth j entitylist) new)) ) ) (entdel obj) (entmake new) ) ) (princ) ) It mostly does what I want, but there are 3 problems: 1. It does not move objects with MLINE and REGION entity type. 2. It transforms only a part of the LINE and 3D FACE entities. For example: one node of a LINE entity moves into the new position and the other node remains in the original position, so the result is a long line, with one node in the correct position and one node in the old position. 3. It works perfectly with most of the TEXT entities, but there are some TEXTs that remain in their original positions, and I can't find out what is the difference between the "working" texts and the "non-working" texts. Any advice how to fix the problems mentioned above? Thanks for any help! Quote Link to comment Share on other sites More sharing options...
marko_ribar Posted September 16, 2014 Share Posted September 16, 2014 (edited) For MLINE ???, REGION and 3D SOLID entities I can't help, but I suppose that for all other types this fix can do... (defun c:customtransform ( / ss i entitylist obj new j x y ) (if (setq ss (ssget "_:L")) (repeat (setq i (sslength ss)) (setq entitylist (entget (ssname ss (setq i (1- i))))) (setq obj (ssname ss i)) (setq new nil) (repeat (setq j (length entitylist)) (cond ( (= 10 (car (nth (setq j (1- j)) entitylist))) (setq x (cadr (nth j entitylist)) y (caddr (nth j entitylist)) ) (setq y (+ (+ (+ 0 332134.109) (* 0.40008331 x)) (* 0.59595102 y))) (setq x (+ (+ (+ 0 1087.012) (* 0.59595102 x)) (* -0.40008331 y))) (setq new (cons (list 10 x y) new)) ) ( (= 11 (car (nth j entitylist))) (setq x (cadr (nth j entitylist)) y (caddr (nth j entitylist)) ) (setq y (+ (+ (+ 0 332134.109) (* 0.40008331 x)) (* 0.59595102 y))) (setq x (+ (+ (+ 0 1087.012) (* 0.59595102 x)) (* -0.40008331 y))) (setq new (cons (list 11 x y) new)) ) ( (= 12 (car (nth j entitylist))) (setq x (cadr (nth j entitylist)) y (caddr (nth j entitylist)) ) (setq y (+ (+ (+ 0 332134.109) (* 0.40008331 x)) (* 0.59595102 y))) (setq x (+ (+ (+ 0 1087.012) (* 0.59595102 x)) (* -0.40008331 y))) (setq new (cons (list 12 x y) new)) ) ( (= 13 (car (nth j entitylist))) (setq x (cadr (nth j entitylist)) y (caddr (nth j entitylist)) ) (setq y (+ (+ (+ 0 332134.109) (* 0.40008331 x)) (* 0.59595102 y))) (setq x (+ (+ (+ 0 1087.012) (* 0.59595102 x)) (* -0.40008331 y))) (setq new (cons (list 13 x y) new)) ) ( (= 14 (car (nth j entitylist))) (setq x (cadr (nth j entitylist)) y (caddr (nth j entitylist)) ) (setq y (+ (+ (+ 0 332134.109) (* 0.40008331 x)) (* 0.59595102 y))) (setq x (+ (+ (+ 0 1087.012) (* 0.59595102 x)) (* -0.40008331 y))) (setq new (cons (list 14 x y) new)) ) ( (= 15 (car (nth j entitylist))) (setq x (cadr (nth j entitylist)) y (caddr (nth j entitylist)) ) (setq y (+ (+ (+ 0 332134.109) (* 0.40008331 x)) (* 0.59595102 y))) (setq x (+ (+ (+ 0 1087.012) (* 0.59595102 x)) (* -0.40008331 y))) (setq new (cons (list 15 x y) new)) ) ( (= 16 (car (nth j entitylist))) (setq x (cadr (nth j entitylist)) y (caddr (nth j entitylist)) ) (setq y (+ (+ (+ 0 332134.109) (* 0.40008331 x)) (* 0.59595102 y))) (setq x (+ (+ (+ 0 1087.012) (* 0.59595102 x)) (* -0.40008331 y))) (setq new (cons (list 16 x y) new)) ) ( t (setq new (cons (nth j entitylist) new)) ) ) ) (entdel obj) (entmake new) ) ) (princ) ) HTH, M.R. Edited September 17, 2014 by marko_ribar code changed Quote Link to comment Share on other sites More sharing options...
BIGAL Posted September 17, 2014 Share Posted September 17, 2014 Maybe try this, Insert dwg into a another as a block you can adjust the x & y scale 0.40008 0.595 etc then do a move press F8 ortho on drag mouse enter 3321434 then again for y 1087 then explode block and purge to remove the BLock definition from within the dwg. Quote Link to comment Share on other sites More sharing options...
aps Posted September 17, 2014 Author Share Posted September 17, 2014 For MLINE ???, REGION and 3D SOLID entities I can't help, but I suppose that for all other types this fix can do... (defun c:customtransform ( / ss i entitylist obj new j x y ) (if (setq ss (ssget "_:L")) (repeat (setq i (sslength ss)) (setq entitylist (entget (ssname ss (setq i (1- i))))) (setq obj (ssname ss i)) (setq new nil) (repeat (setq j (length entitylist)) (cond ( (= 10 (car (nth (setq j (1- j)) entitylist))) (setq x (cadr (nth j entitylist)) y (caddr (nth j entitylist)) ) (setq y (+ (+ (+ 0 332134.109) (* 0.40008331 x)) (* 0.59595102 y))) (setq x (+ (+ (+ 0 1087.012) (* 0.59595102 x)) (* -0.40008331 y))) (setq new (cons (list 10 x y) new)) ) ( (= 11 (car (nth (setq j (1- j)) entitylist))) (setq x (cadr (nth j entitylist)) y (caddr (nth j entitylist)) ) (setq y (+ (+ (+ 0 332134.109) (* 0.40008331 x)) (* 0.59595102 y))) (setq x (+ (+ (+ 0 1087.012) (* 0.59595102 x)) (* -0.40008331 y))) (setq new (cons (list 11 x y) new)) ) ( (= 12 (car (nth (setq j (1- j)) entitylist))) (setq x (cadr (nth j entitylist)) y (caddr (nth j entitylist)) ) (setq y (+ (+ (+ 0 332134.109) (* 0.40008331 x)) (* 0.59595102 y))) (setq x (+ (+ (+ 0 1087.012) (* 0.59595102 x)) (* -0.40008331 y))) (setq new (cons (list 12 x y) new)) ) ( (= 13 (car (nth (setq j (1- j)) entitylist))) (setq x (cadr (nth j entitylist)) y (caddr (nth j entitylist)) ) (setq y (+ (+ (+ 0 332134.109) (* 0.40008331 x)) (* 0.59595102 y))) (setq x (+ (+ (+ 0 1087.012) (* 0.59595102 x)) (* -0.40008331 y))) (setq new (cons (list 13 x y) new)) ) ( (= 14 (car (nth (setq j (1- j)) entitylist))) (setq x (cadr (nth j entitylist)) y (caddr (nth j entitylist)) ) (setq y (+ (+ (+ 0 332134.109) (* 0.40008331 x)) (* 0.59595102 y))) (setq x (+ (+ (+ 0 1087.012) (* 0.59595102 x)) (* -0.40008331 y))) (setq new (cons (list 14 x y) new)) ) ( (= 15 (car (nth (setq j (1- j)) entitylist))) (setq x (cadr (nth j entitylist)) y (caddr (nth j entitylist)) ) (setq y (+ (+ (+ 0 332134.109) (* 0.40008331 x)) (* 0.59595102 y))) (setq x (+ (+ (+ 0 1087.012) (* 0.59595102 x)) (* -0.40008331 y))) (setq new (cons (list 15 x y) new)) ) ( (= 16 (car (nth (setq j (1- j)) entitylist))) (setq x (cadr (nth j entitylist)) y (caddr (nth j entitylist)) ) (setq y (+ (+ (+ 0 332134.109) (* 0.40008331 x)) (* 0.59595102 y))) (setq x (+ (+ (+ 0 1087.012) (* 0.59595102 x)) (* -0.40008331 y))) (setq new (cons (list 16 x y) new)) ) ( t (setq new (cons (nth j entitylist) new)) ) ) ) (entdel obj) (entmake new) ) ) (princ) ) HTH, M.R. Thank you, but I've got an error message when I try to run it: error: bad argument value: non-negative: -1 What does it mean? With only the first condition and the else condition it works like before: (defun c:customtransform () (if (setq ss (ssget "_:L")) (repeat (setq i (sslength ss)) (setq entitylist (entget (ssname ss (setq i (1- i))))) (setq obj (ssname ss i)) (setq new nil) (repeat (setq j (length entitylist)) (cond ( (= 10 (car (nth (setq j (1- j)) entitylist))) (setq x (cadr (nth j entitylist)) y (caddr (nth j entitylist)) ) (setq y (+ (+ (+ 0 332134.109) (* 0.40008331 x)) (* 0.59595102 y))) (setq x (+ (+ (+ 0 1087.012) (* 0.59595102 x)) (* -0.40008331 y))) (setq new (cons (list 10 x y) new)) ) ( t (setq new (cons (nth j entitylist) new)) ) ) ) (entdel obj) (entmake new) ) ) ) But if I add the second or any other condition the error message apears. Quote Link to comment Share on other sites More sharing options...
marko_ribar Posted September 17, 2014 Share Posted September 17, 2014 That's because I didn't test it... I've updated fix, should work now as expected, but I think BIGAL's suggestion is what I should do... Of course apply code on block of entire DWG, explode and purge that block... M.R. Quote Link to comment Share on other sites More sharing options...
aps Posted September 17, 2014 Author Share Posted September 17, 2014 Maybe try this, Insert dwg into a another as a block you can adjust the x & y scale 0.40008 0.595 etc then do a move press F8 ortho on drag mouse enter 3321434 then again for y 1087 then explode block and purge to remove the BLock definition from within the dwg. Thank you for the idea, but more DWGs with such content will arrive soon, and I want to provide a foolproof tool to my colleagues. Quote Link to comment Share on other sites More sharing options...
aps Posted September 17, 2014 Author Share Posted September 17, 2014 That's because I didn't test it... I've updated fix, should work now as expected, but I think BIGAL's suggestion is what I should do... Of course apply code on block of entire DWG, explode and purge that block... M.R. Can you show me the updated version of the code? Thank you! Quote Link to comment Share on other sites More sharing options...
marko_ribar Posted September 17, 2014 Share Posted September 17, 2014 Can you show me the updated version of the code? Thank you! http://www.cadtutor.net/forum/showthread.php?88736-Custom-transformation-and-entity-types&p=#2 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted September 18, 2014 Share Posted September 18, 2014 2 things if the scale and move are different for each then you will need to change Marko's code to allow for user input of these values. Back to mine you could ask the questions about the scale and move and automate using the insert method as well. Just open new dwg and run a lisp. Quote Link to comment Share on other sites More sharing options...
aps Posted September 22, 2014 Author Share Posted September 22, 2014 Hi, I'm back with my problem. Thank you Marco and BIGAL for your help! Marko's code works fine, except for ellipses and regions. Therefore I took into consideration the block idea. I extended the LISP file with Lee Mac's Polyline to Block code, so now it converts all object into a single block and then transform it into the new coordinate system. I was happy because after exploding the transformed block I got exactly what I want, but during data verification I found that this method results inaccurate coordinates. I checked with manual calculations that Marko's transform-only code is deadly accurate. But when I convert the objects into a single block (either with Lee Mac's method or with hand in AutoCAD) and then run the transformation routine on the block, inaccuracy occurs. The degree of inaccuracy seems to be constant and it is between 10 and 100 cm (4-39"), depends on the basepoint of the block selected before the transformation. Why does this inaccuracy occur? How can I get rid of it? Quote Link to comment Share on other sites More sharing options...
aps Posted September 22, 2014 Author Share Posted September 22, 2014 I made some measurements: transforming directly a single circle (diameter = 3 cm) with Marko's good code and transforming after converted to a block results around 6 mm (1/4") difference. With a polyline the difference is bigger. Converting to block and transforming more than 1 object the error is increasing. I observed that using (0,0) as the block's base point gives the biggest error, while using EXTMIN as the base point results lower error. I've got the smallest difference when I use the center of the extent (EXTMAX - EXTMIN / 2) as the base point, it's around 4 - 7 cm, but it's interesting that the error is not constant, when I use the center of the extent as the base point, I've got bigger errors close to EXTMIN and smaller errors close to EXTMAX. Unfortunately I don't know anything about AutoCAD's block handling, so I can't find out how to elliminate the error generated by converting the objects into a block before transformation. Do you have any ideas? Quote Link to comment Share on other sites More sharing options...
