liamdonnelly0209 Posted September 15, 2014 Posted September 15, 2014 Hi All. Im assuming this could be done via a lisp but not entirely sure. Im wondering if there is a way to create a layout with border plus a viewport that uses a polyline/block set in model space as its reference for its limits. Almost the opposite way that the change space command works but creating a viewport in the process. I basically have some polylines setup in a drawing that essentially ring around certain areas and would like to create layouts from these polylines and use them for the boundaries. Im wondering if there is also a possiblity that if i create a block or something, it could use the block name to create a tab also. Thank you in advance. Quote
zaphod Posted September 15, 2014 Posted September 15, 2014 There is a lsp called vp-outline which does just the opposite, I got if off of www.jtbworld.com. it might be of some help. Quote
liamdonnelly0209 Posted September 15, 2014 Author Posted September 15, 2014 Yeah that is similar to the Change Space express tool. im hoping for something thats the reverse with tab creation from the polyline/block. some other quite good lisps on that site though thank you Quote
BIGAL Posted September 16, 2014 Posted September 16, 2014 Maybe something like use chspace and bring to paperspace create bounding box and rescale object to fit your titleblock, mview ob pick (entlast) mspace zoom xp so as to set scale. I would probably get centre point in model space as first step so can centre the mview at a scale. There is a few un answered questions such as does the shape have a scale for plotting. Post a dwg with object in mspace a layout with object in pspace at desired scale Quote
liamdonnelly0209 Posted September 17, 2014 Author Posted September 17, 2014 There will be no scale for the boundary in model space, and the scaling in the layout will not be important either. I imagine the tool would find a specific block in model space (for arguements sake called - Arch) and create a viewport on a tab that has the same name, using that block as the boundary of the viewport. IE the reverse of Change Space, going from model to layout with reference of block name and layout name so it knows where it will be sent to. A block in the border could be the reference for it to copy to the center point and scale inside so the viewport does not exceed the blocks boundaries. Does that make sense? Quote
liamdonnelly0209 Posted September 17, 2014 Author Posted September 17, 2014 or.... With all the layouts set up, a lisp could open the tab, and have the viewport do a zoom/window around a block that has a specific name attached to that layout? Is that something thats possible? That would most likely be easier to achieve i imagine? Quote
BIGAL Posted September 18, 2014 Posted September 18, 2014 Reading another post today you can zoom Object so create a mview go to mspace Z O, you could probably join all the steps into a lisp create layout make a mview mspace pick obj1 repeat. Using measure Block you could create a simple rectang block on one layer you can then get all these blocks and they will be in correct order of creation, you can then Zoom O obj1 Zoom O obj2 etc. It needs 2 or 3 bits of code to be joined together You need to post a dwg ;simple example draw a rectang in "Model" go to a layout Mview then Mspace (setq obj (entsel "\npick rectang")) (command "Zoom" "O" obj "") Quote
liamdonnelly0209 Posted September 22, 2014 Author Posted September 22, 2014 Sorry ive not been able to send a drawing as of yet. The code you sent helps me lots as im almost there now. Is there a way of selecting a block name for the "obj" line instead of having to select it manually? im trying to set this up automated as i have 500+ drawings i would like to test this out on with various layouts being created. so far i have set it up like below, but as mentioned i would like it to zoom to the block called Arch instead of the manual process of selecting it. (defun c:CVP () (setq obj (entsel "\npick rectang")) (setvar 'CTAB "Arch") (command "._MSPACE") (command "Zoom" "O" obj "") (command "._PSPACE") (command "._ZOOM" "E") (princ) ) Quote
