Can someone help me with this:
My commands are repeating 8 or 9 times each. It takes a really long time for this to load and I can't figure out why its loading each command over and over again.
any help is much appreciated
Had you been making any additions or deletions to acad.pgp prior to experiencing this problem?
yes, I had added new commands and changed certain short cuts i.e: 'C' is copy now not circle etc. All my commands still work it just takes a while for the command alias to open. Also I think every time I open it duplicates the commands again.
I think you may have done more that just added new commands. I'd start over with a clean acad.pgp and be a little more careful.
Open the acad.pgp file and see if those repeats show, I assume they will. Edit the file, save, and try again. It will be easier to edit in the file rather than that dialog.
Go to Tools, Customize, Edit program parameters - acad.pgp.
