JD - I have no actual physical part. I will be creating it on a 3D printer. But I will post the drawing part - which this tool will help to align onto a 1" diameter shaft...
  • Replies 24
  • DaveS777
    13
  • JD Mather
    8
  • ReMark
    2
  • f700es
    1
Posted Images
Thanks to everyone who tried to help, and others who thought about it; but didn't wish to contribute to the confusion...
I've fixed the various alignment tool drawings. Learned how to use 'align' just a little bit. Really need to know a ton more on that tool; but figured out how to deal with it on a single point basis - which worked for me...
I haven't ever been drawing stuff by eyesight, or willy nilly. Just getting stuff aligned to circular objects is a bit fun. Previously thought 'center' would work; but I believe AutoCad has some 'bugs' or other difficulties when you are 'centering' to a Helix shaped object. Sort of like the 'wobble' which Nestly previously some time back mentioned.
So, when I centered everything - and also put some stuff at origin point - (yeh, I'm using 0,0,0 sometimes) - I thought it was all correct. However, the Helix solid - does not center correctly.
But today, in working to correct it all - I was able to use some Faces, etc. and so I found out that it was not properly centering; and so then I was able to compensate somewhat for the problem. Anyway, I redrew it just a bit; and also dragged in various required solids; and using 'align' etc. and a corrected Center - got this all to fit together with no errors... (At least Mini Magics now declares 'error free')
D.
ROTOR complete.dwg
Alignment Tool 60.dwg
ALIGNMENT Tool 36.dwg
For anyone somewhat wondering how it fits...
I haven't checked in the latest release - but I think in earlier releases the Helix in AutoCAD was not very precise.
Do you have access to Autodesk Inventor or Fusion 360?
