Is it possible to have 3d image of trees and shrub in autocad. sort of designing the tree and adding it to our enviroment
You can create a 3D model of a tree in AutoCAD if that is what you want. There is a tutorial here at CADTutor that steps you through the process. You can also attach images of trees and shrubs to a drawing to be used as a background for instance.
