gvgbabu Posted August 29, 2014 Posted August 29, 2014 hi all i have inserted a table in a drawing. after i re open the drawing the table is not visible. when i explode the table it is saying that 1 external reference. please guide me how to see the table in the drawing and how to explode this type of entities. i am here attaching my drawing. please help me thanks in advance gvg Drawing1.dwg Quote
gvgbabu Posted August 29, 2014 Author Posted August 29, 2014 when i right click on the table and select update table then it's visible, explodable and modificable. i didnt get any information on update table. let me know what is that property. gvg Quote
ReMark Posted August 29, 2014 Posted August 29, 2014 Did you insert the table as an OLE object? What layer is the table on? Is the layer off or frozen? Quote
gvgbabu Posted August 29, 2014 Author Posted August 29, 2014 Hi remark I inserted the table using vb.net the table layer is colsch. layer is not off or frozen? please explain about update table as i perviously mentioned. Quote
gvgbabu Posted August 29, 2014 Author Posted August 29, 2014 when selecting and listing select/all/enter/list/p.it shows ACAD_TABLE. i would like to know regarding update table only in autocad 2007. Quote
ReMark Posted August 29, 2014 Posted August 29, 2014 The only update table option I am aware of would have applied to AutoCAD 2008 onward as that is when the DataLink feature was added. And I think you have made it clear enough we are talking about AutoCAD 2007. Thanks for the reminder. Quote
BlackBox Posted August 29, 2014 Posted August 29, 2014 Firstly, to respect other's time... Here's a duplicate thread. Second, this thread should be moved to the .NET forum, given that we now know the OP is experiencing difficulty with a result of inserting of the Table using code. Lastly, to the OP, kindly post your code if you want help with it... To venture a guess in the dark starting with the simplest thing to overlook, is that when you instantiate Dim table as Table = new Table(), you may have neglected to call table.SetDatabaseDefaults() Method prior to modifying Object, and ultimately .AppendEntity(table) & .AddNewlyCreatedDBObject(table, True), followed by .Comit() HTH Quote
