vespazari Posted August 29, 2014 Posted August 29, 2014 Hello all, New to the cad forum...and new to inventor after taking a two year break. I am creating an equal angle frame member using the frame generator, everything seems to work as per usual. 1. I select insert frame, select my iso structural section, select the dimensions of the section. then I select an edge for placement and also orientation. The green preview looks exactly how I want it to and I click apply. But when the frame member shows up on screen it shows up in a different location. It is like there is a offset or displacement , but the vertical and horizontal offsets are set to 0.00mm Has anyone got any suggestions? Thank You Nate Quote
