I'm having an issue with model space viewports in a drawing. I'm using Civil 3D 2014 and the drawing contains a alignments, profiles, assemblies, a corridor, cross-sections and quantities tables.
I used the VPORTS command to split the screen into three model space viewports like so:
The idea being that I can have a look at the cross-sections, plan view and an isometric of the corridor all at the same time.
However, when I click from one viewport to another, it zooms all viewports out like ths:
And this happens in the command line:
"Command: Regenerating model.
Regenerating model.
Regenerating model.
Regenerating model.
Command:
Command: (ai_tiledvp 1 nil)
Command:
Command:
Command: (ai_tiledvp 3 "_B")
Command: Regenerating model."
It only does this in this particular drawing (to my knowledge, anyway) so I'm guessing it's some ambient setting that got toggled by mistake, but I can't find anything that seems like it might fix the issue.
Also, on a side note I tried typing ai_tiledvp into the command line to see if it was a system variable, but alas it was no avail.
Any help is much appreciated.
Thanks.
You need to set UCSFOLLOW to 0 in each vport.
