  sidhu412 said:
Bingooooooooooo
Great.........!
That's 100% What I needed You are Genius Mr. Marko_Ribar.
Thanxxxxxx a lot
Regards,
Sidhu
You're welcome, Sidhu...
All the best in your work, I hope you'll find useful posted code...
M.R.
  • Replies 22
  • marko_ribar
    7
  • sidhu412
    6
  • ReMark
    5
  • OMEGA-ThundeR
    3
Posted Images
Wow this is great Marko!!
This is definitely a helpful tool
Thanks
~Greg
Thanks Greg, I've cleaned code further more... Had mistake in checking weather picked entities belong to curve entities... Now fixed that issue and also changed defined functions to be local to main command function... This version I use now in my start-up acaddoc.lsp...
(defun c:exb2c ( / colect_entdata store_entdata colect_modified_entdata sel_mod_ents
                  hig osm c1 c2 p ss entdata )
 (defun colect_entdata ( / ss i ent entdata )
   (setq ss (ssget "_X"))
   (setq i -1)
   (while (setq ent (ssname ss (setq i (1+ i))))
     (setq entdata (cons (entget ent) entdata))
   entdata
 (defun store_entdata nil
   (setq entdata (colect_entdata))
 ;;; Modify entities ;;;
 (defun colect_modified_entdata ( / ss i ent entdatachk entdatamod )
   (setq i -1)
     (setq entdatachk (cons (entget ent) entdatachk))
   (foreach data entdatachk
     (if (not (vl-some '(lambda ( x ) (equal x data 1e-6)) entdata))
       (setq entdatamod (cons data entdatamod))
   entdatamod
 (defun sel_mod_ents nil
   (setq ss (ssadd))
   (foreach data (colect_modified_entdata)
     (ssadd (cdr (assoc -1 data)) ss)
 ;;; Main function ;;;
 (vl-load-com)
 (setq hig (getvar 'highlight))
 (setq osm (getvar 'osmode))
 (setvar 'osmode 0)
 (if (not (or etrim (not (vl-catch-all-error-p (vl-catch-all-apply 'load (list (findfile "extrim.lsp")))))))
     (alert "\nExpress Tool EXTRIM not available - quitting...")
     (exit)
 (setq c1 (car (entsel "\nPick first curve")))
 (while (vl-catch-all-error-p (vl-catch-all-apply 'vlax-curve-getstartparam (list c1)))
   (prompt "\nPicked entity isn't curve entity. Try again...")
 (setq c2 (car (entsel "\nPick second curve")))
 (while (vl-catch-all-error-p (vl-catch-all-apply 'vlax-curve-getstartparam (list c2)))
 (initget 1)
 (setq p (getpoint "\nPick or specify point between 2 prviously picked curves where do you want extrim to be processed : "))
 (store_entdata)
 (etrim c1 p)
 (sel_mod_ents)
 (command "_.copybase" '(0.0 0.0 0.0) ss "")
 (command "_.undo" "3")
 (etrim c2 p)
 (command "_.pasteclip" '(0.0 0.0 0.0))
 (setvar 'osmode osm)
 (setvar 'highlight hig)
HTH, M.R.
