BIGAL Posted August 19, 2014 Posted August 19, 2014 (edited) I think a bit of searching here would have produced an answer I know I posted a do lots offset routine that was based on + & - values to imply sides -4 -6 -8 etc this could have been changed to a defun (offs -4)(offs -9) using word etc it would be easy to produce the code the other alternative is the old fashioned script again Word or excel to create, but yes still need a list of numbers, will have to find code I think I did this one at home. Here is the main code it will need a mod so that you run it like you want http://www.cadtutor.net/forum/showthread.php?85524-Multiple-offset-plines-done-easy-with-width-and-color&highlight=offset some one can rip it apart and make shorter I am sure back to work now. Will try later. (load "multi") (ah:multpl -4) (ah:multpl -6) (ah:multpl - Edited August 19, 2014 by BIGAL Quote
sidhu412 Posted August 19, 2014 Author Posted August 19, 2014 asos2000 said: I think that it is good start (defun c:mofst (/) (setq doc (vla-get-ActiveDocument (setq *acad (vlax-get-Acad-Object))) spc (if (zerop (vla-get-activespace doc)) (if (= (vla-get-mspace doc) :vlax-true) (vla-get-modelspace doc) (vla-get-paperspace doc)) (vla-get-modelspace doc))) (vl-load-com) (setq uFlag (vla-startUndoMark doc)) (setq obj (entsel "\nSelectObject")) (setq s (getpoint "\nPick Offset side")) (setq o1 (getreal "\nWhat is distence for 1st offset?")) (setq o2 (getreal "\nWhat is distence for 2nd offset?")) (setq o3 (getreal "\nWhat is distence for 3rd offset?")) (vl-cmdf "_.offset" o1 obj s "") (vl-cmdf "_.offset" o2 obj s "") (vl-cmdf "_.offset" o3 obj s "") (setq uFlag (vla-EndUndoMark doc)) ) (defun *error* (msg) (and uFlag (vla-EndUndoMark doc)) (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*") (princ (strcat "\n** Error: " msg " **"))) (princ)) Thnxxxxxxxxxxxxxx a lot, This is exactly what I wanted. Really appreciated. Thnx again man. Regards, Sidhu Quote
BIGAL Posted August 19, 2014 Posted August 19, 2014 This is a variation of the asos200 were you may have more than 3 perhaps from some excel sheet etc reduced the code just for testing should put the error checking etc back in for rigidity. The offset code defun c:mosft can be done easy in word or excel probably the way to go is something like (multpl 12 14 16 32 23) (multpl 12 14 16 32 23 34 45 67 78) as many variables as required ;just need to keep the 6 top lines and add the rest of lines as required (vl-load-com) (defun c:mofst (o1 obj s/ ) (vl-cmdf "_.offset" o1 obj s "") ) (setq obj (entsel "\nSelectObject")) (setq s (getpoint "\nPick Offset side")) (c:mofst 12 obj s) (c:mofst 14 obj s ) (c:mofst 16 obj s) (c:mofst 22.5 obj s) (c:mofst 34.75 obj s) Quote
sidhu412 Posted August 19, 2014 Author Posted August 19, 2014 BIGAL said: This is a variation of the asos200 were you may have more than 3 perhaps from some excel sheet etc reduced the code just for testing should put the error checking etc back in for rigidity. The offset code defun c:mosft can be done easy in word or excel probably the way to go is something like (multpl 12 14 16 32 23) (multpl 12 14 16 32 23 34 45 67 78) as many variables as required ;just need to keep the 6 top lines and add the rest of lines as required (vl-load-com) (defun c:mofst (o1 obj s/ ) (vl-cmdf "_.offset" o1 obj s "") ) (setq obj (entsel "\nSelectObject")) (setq s (getpoint "\nPick Offset side")) (c:mofst 12 obj s) (c:mofst 14 obj s ) (c:mofst 16 obj s) (c:mofst 22.5 obj s) (c:mofst 34.75 obj s) Thanks for the Help. Regards, Sidhu Quote
Tharwat Posted August 19, 2014 Posted August 19, 2014 BIGAL , take a look at the following and compare it with your suggestion (if (and obj s) (mapcar '(lambda (i) (vl-cmdf "_.offset" i obj s "")) '(1. 2. 3.)) ) Quote
BIGAL Posted August 20, 2014 Posted August 20, 2014 Thanks Tharwat I realised I needed to make the offsets a list the lambda function is a good way to step through a unknown list of offsets. I also looked at the complexity of the code and broke it down to something simple just keep entering offsets till you run out. Sometimes we over complicate an answer. (defun C:MULOFF ( / obj s off) (vl-load-com) (setq obj (entsel "\nSelectObject")) (setq s (getpoint "\nPick Offset side")) (while (/= (setq off (getreal "\nEnter offset or Enter to exit") nil) (vl-cmdf "_.offset" off obj s "") ) ) Quote
suryacad Posted August 21, 2014 Posted August 21, 2014 Hi guys. Can some body please explain how these codes that are pasted here are used? i have used LISPS that can be downloaded. and then appload and use the call function as mentioned in lee mac's website. got no idea how to use codes posted this way. Thank you. Quote
ketxu Posted August 24, 2014 Posted August 24, 2014 Maybe sth like this : ;Multi Offset base (defun c:mob(/ o s l) (if (setq o (entsel "\nSelect Object") s (getpoint "\nPick Offset side") l (read (strcat "(" (lisped "Type all distance, seperate by space ..") ")")) ) (mapcar '(lambda(i)(vl-cmdf "_.offset" i o "_non" s "")) l) ) ) ;Multi Offset Continous (defun c:moc(/ o a s l) (if (setq o (entsel "\nSelect Object") a 0 s (getpoint "\nPick Offset side") l (read (strcat "(" (lisped "Type all distance, seperate by space ..") ")")) l (mapcar '(lambda(x)(setq a (+ x a))) l) ) (mapcar '(lambda(i)(vl-cmdf "_.offset" i o "_non" s "")) l) ) ) Quote
sidhu412 Posted August 24, 2014 Author Posted August 24, 2014 ketxu said: Maybe sth like this : ;Multi Offset base (defun c:mob(/ o s l) (if (setq o (entsel "\nSelect Object") s (getpoint "\nPick Offset side") l (read (strcat "(" (lisped "Type all distance, seperate by space ..") ")")) ) (mapcar '(lambda(i)(vl-cmdf "_.offset" i o "_non" s "")) l) ) ) ;Multi Offset Continous (defun c:moc(/ o a s l) (if (setq o (entsel "\nSelect Object") a 0 s (getpoint "\nPick Offset side") l (read (strcat "(" (lisped "Type all distance, seperate by space ..") ")")) l (mapcar '(lambda(x)(setq a (+ x a))) l) ) (mapcar '(lambda(i)(vl-cmdf "_.offset" i o "_non" s "")) l) ) ) That's really very nice tool, thnx for Help Regards, Sidhu Quote
hanhphuc Posted August 24, 2014 Posted August 24, 2014 ketxu said: You're welcome, just an idea kết xử is always the solution thanx idea (read (strcat "(" str ")")) @7o7 :-) Quote
