Sengna Posted August 7, 2014 Posted August 7, 2014 How can i unlock the drawing for editing? i received the drawing from other client that is locked. I tried to offset a line or move but it didn't work, it showed the little lock icon when i hover over the line. appreciate any help. Quote
MSasu Posted August 7, 2014 Posted August 7, 2014 Please note that the layer containing that entity is locked, not the entire drawing. Just open the pop-up list of layers (or call LAYER command) and click on the lock icon of the layer containing said item. 1 Quote
Sengna Posted August 7, 2014 Author Posted August 7, 2014 MSasu said: Please note that the layer containing that entity is locked, not the entire drawing. Just open the pop-up list of layers (or call LAYER command) and click on the lock icon of the layer containing said item. "Pop up list of layers" were you referring to layer manager? Quote
Sengna Posted August 7, 2014 Author Posted August 7, 2014 I went to check on the layer manager window, all layers are unlocked, but i was unable to do anything ex: move, offset, match Prop, change color.... What else could each be? anybody have any idea? Quote
Sengna Posted August 7, 2014 Author Posted August 7, 2014 ReMark said: Have you asked the client for some help? He didn't answer the phone, he was not in the office, don't know when he will get back to me. Quote
ReMark Posted August 7, 2014 Posted August 7, 2014 Can you attach a copy of the drawing to a subsequent post? Quote
Sengna Posted August 7, 2014 Author Posted August 7, 2014 Due to their confidential I can't not post their drawing here. hope you understand. i guess i can try to explode the whole drawing. Quote
ReMark Posted August 7, 2014 Posted August 7, 2014 It's your drawing so go right ahead. Let us know what happens. Quote
Sengna Posted August 7, 2014 Author Posted August 7, 2014 Here is probably what happen to this file, i thought it's interesting to share, i am not go na waste my whole day try to get into this drawing cause i tried my best. I will let them figure that out and get back to me. Quote
SLW210 Posted August 7, 2014 Posted August 7, 2014 Looks like it is a Geometric Constraint called Fixed Quote
RobDraw Posted August 7, 2014 Posted August 7, 2014 I was going to suggest that a constraint was applied. I don't use them so I thought it better to wait for someone else to suggest and agree with them. Quote
Sengna Posted August 7, 2014 Author Posted August 7, 2014 I tried to removed the geometric constraint using DELCONSTRAINT, it still show that padlock next to any line i clicked. I used DELCONSTRAINT command before for other dwg, it worked but not on this one. i tried to just copy any obj on the screen and set a side but nothing being copied. Weird. Quote
SLW210 Posted August 8, 2014 Posted August 8, 2014 Can you remove everything else and -PURGE and post your drawing file? Quote
Sengna Posted August 12, 2014 Author Posted August 12, 2014 just a quick update, they person who originally drew this drawing got back to me, he unlocked and sent it back to me so good to go, thanks everyone for your input. Quote
Karendse Posted March 1, 2021 Posted March 1, 2021 Hi! Can you please help me I have the same problem! Thanks Quote
steven-g Posted March 1, 2021 Posted March 1, 2021 Same answer as 7 years ago, can you post a copy of the .dwg Or get in touch with the sender if this is locked by an external program as they are the only ones who can unlock it. Quote
ReMark Posted March 1, 2021 Posted March 1, 2021 (edited) On 3/1/2021 at 7:37 AM, Karendse said: Hi! Can you please help me I have the same problem! Thanks By "locked" are you saying the drawing is password protected? If not, then how exactly is it locked? Edited March 1, 2021 by ReMark Quote
ammobake Posted March 1, 2021 Posted March 1, 2021 This kind of locking can technically be done in the file properties. That may also be something to check out. Is the file read only in properties? -ChriS Quote
Dana W Posted March 2, 2021 Posted March 2, 2021 If it is read only just do a SAVE AS another copy another name.dwg Quote
