nicolas Posted August 6, 2014 Share Posted August 6, 2014 Dear All, I am looking for a way to add justification to a newly created text palette. I have a mtext set to the correct layer, color and size and justification. I dragged it to the tool palette and everything works well except for the text justification. I have checked the properties on the palette but no solution here. Is there a way to add a system variable to ^C^C_mtext Your help would be very valuable. Thanks. Quote Link to comment Share on other sites More sharing options...
nicolas Posted August 6, 2014 Author Share Posted August 6, 2014 Hi, I have found the solution. In the palette, need to insert the following command: ^C^C_textsize;1.65;mtext;\j;MC Thanks. Quote Link to comment Share on other sites More sharing options...
