Hi Guys,:)
i have some drawings with blocks in them, (CAD file has been Attached below):fishing:
Sample Block.dwgFetching info...
sometimes, i need to trim the lines inside the blocks. (Screenshot below):bloodshot:
As Trim Doesn't Work on Blocks, i had to explode or burst the blocks and then trim the lines. :wacko:
But i don't want to burst or explode the blocks, because the blocks have properties.:rtfm:
Is there any lisp routine that can fulfill my requirement?
or, does anybody know a way to trim the lines inside the blocks without exploding?:unsure:
PS:
i know that use "edit block in place" and then use the "trim" command, but using this method 155 times can be irritating.:itsover:
I would make one block, already trimmed, with the correct properties. Then copy it around your dwg 155 times. Search for "nested trim" if that wont work for you !
Actually these blocks look similar, but the dimensions and the properties of the blocks vary each time, so i can't copy the blocks around,:)
BTRIM, trims to objects nested in blocks and external references. It doesn't trim the block itself so this command doesn't help me,
Well you could always add a stretch parameter or two into your block (that is trimmed), therefor allowing you to copy one block around the dwg, and then go modify it slightly for each instance based on the dimensions?
Hopefully someone will come along and offer you a lisp solution
No, Actually most of these drawings are outsourced or it is from a 3D Modelling Software. So Making Dynamic Blocks is out of the options.:unsure:
I tried to make a lisp on my own, The lisp opens the block in "refedit" mode and then trim the line8)
(defun c:TRB()
(command "-refedit" PAUSE "Ok" "All" "Yes")
(command "TRIM" "" PAUSE "" )
(command "_.refclose" "S")
(command "regen") ;regenerate
(princ "\n:::Type \"TRB\" to trim blocks:::")
The Only Problem with the above code is that i have to click twice,:oops:
Autocad really needs to make it so you can trim around a block. it would it so much easier. I don't see the benefit of not being able to.
This may help or not search for cookiecutter.lsp it wil require say for above pick 4 pts.
I already tried that LISP Bigal, :)
The Only Problem in the "Cookiecutter" is that it "BURST's" The Block, if the block gets burst the properties wont be available, :ouch:
Any Other Ideas?
Because you know the shape of the block create a new block that is the correct shape from a pline explode once then try wipeout picking pline.
the block shape is sometimes the same, sometimes it is not the same, so making a wipeout will be hard.:unsure:
Please see the below attachment for details, :geek:
SAMPLE2.dwgFetching info...
U can See That the shape of the block changes every time, if i had to use the wipeout method, it wouldn't be so productive,:o
Can U give me some more ideas on that LISP that i had posted? (coz, i find the lisp method easy to use)
