JDA Posted July 31, 2014 Posted July 31, 2014 Hi I am relatively new to AutoCAD. I'm running into problems when I try to bring in an architects plan into my civil base plan. Only some of the lines and objects appear in my working drawing. A lot of the live layers in the architects plans do not xref into my drawing and I cannot figure out why. I've turned on all layers to no avail. -JDA Quote
JDA Posted August 1, 2014 Author Posted August 1, 2014 The objects are lines and exploded blocks. Quote
RobDraw Posted August 1, 2014 Posted August 1, 2014 Are all the layers on and thawed in both drawings? Quote
JDA Posted August 1, 2014 Author Posted August 1, 2014 I checked to make sure and everything is thawed on both drawings. The reference file has missing xrefs but like I said all the layers I want in my drawing are live in the reference file. Quote
RobDraw Posted August 1, 2014 Posted August 1, 2014 I'm stumped. Can you post stripped down versions of both files? I just need enough objects to see the problem. Quote
