Does anybody have any idea if a lisp routine can be created so that if a block (detail .dwg) is inserted from a detail library that a hyperlink can be added to the block as it is being inserted so that the hyperlink can be used to later open the detail.dwg in it's remote location.
We're looking to use extensive folders/sub-folders to organize our detail library and do not want to browse through many folders/sub folders when searching for the block in question.
(Side note...
We don't use xrefs to attach details to detail sheets as we like to edit attribute text within the block).
Using Autocad Architecture 2014.....
Many thanks for your help!
hi tplight, i'm not sure but can try
command: Field -> Linked -> Hyperlink ?
