rodeo0630 Posted July 24, 2014 Posted July 24, 2014 Is there a lisp for detailing a drawing. the lisp should window area that I want to scale up. Please see the attach file. On the left is the full 1:1 drawing and on the right is scaled to 2x. Appreciate your help. TIA Quote
BIGAL Posted July 24, 2014 Posted July 24, 2014 Just use layouts and multiple MVIEWS thats what their for. Quote
rodeo0630 Posted July 24, 2014 Author Posted July 24, 2014 thanks but I need the scaled drawing to be on the model tab too. Quote
Cad64 Posted July 24, 2014 Posted July 24, 2014 Just create model space viewports then: http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%202010%20User%20Documentation/index.html?url=WS1a9193826455f5ffa23ce210c4a30acaf-75d9.htm,topicNumber=d0e31581 Quote
rodeo0630 Posted July 24, 2014 Author Posted July 24, 2014 thanks . I found a lisp but it's a circle detailing I cannot make it as a square. details.lsp Quote
BIGAL Posted July 25, 2014 Posted July 25, 2014 Writing code for copy, pick objects, put over their, scale done ????? Box around use extrim to clip By the time I typed this I had done it. Looking at the code some of it can be simplifield as above by using extrim this may also help the need to explode some objects. It was obviously written for a specific task as it has a lot of hard coded stuff in it. from your images above I would suggest start again using a lisp that copy move use pick pts as surround extrim done. Its almost the weekend will try to do if someone else does not beat me to do this simpler than code provided. Quote
