Fillet Radius goes to Zero every DWG
:? Hello,
My first post...new to CADTutor...
I am using AC 2009 and the Fillet radius keeps going back to zero even though I save the drawing.
When I open the drawing again whala, Fillet radius is back to zero!
What causes this?
Other AC users do not experience this problem...:(
  • Replies 40
  • jimdi4
    16
  • dbroada
    6
  • Tiger
    5
  • totzky
    3
Posted Images
Welcome...
Is there anything in your Startup Suite, acaddoc.lsp file, or third party add-ons that could be causing this?
Startup Suite?..My machine is bare bones, no third part anything, no lisp routines...:o
FILLETRAD is the same thing as setting the radius in the fillet command....This didn't help either...any other ideas?
what you could do is add FILLETRAD to your acaddoc.lsp, that way it's set everytime you start AutoCAD. It would only work if you usually use the same radius though..
I'm not that good at editing lisp routines matter of fact I never did it but I did find that file you refered to....How would I add that FILLETRAD to the lisp routine to default my Radius to lets say .075?
here is my acaddoc.lsp lisp file :
;;;*-*TXT acad.lsp is loaded once, acaddoc.lsp is loaded for each
;;; document, s::startup in any case is called after acaddoc.lsp
;;; has been loaded
;;(if (= nil acad_helpdlg)
;; (progn
;; (load "acadr15.lsp")
;; (load (strcat (getvar "menuname") ".mnl"))
(if (= nil genlade)
(princ (load "gen/acadm.lsp" "\nError: acadm.lsp not loaded!"))
(if acadmappend (setq s::startup (acadmappend s::startup)))
;;; has been loaded
;; (progn
(if (= nil genlade)
I'm not a star at Lisp either so if I'm wrong, please someone correct me, but I would add the line (setvar "filletrad" 0.075) to the very very end of your acaddoc-file.
both my sentiments and how I would do it.
I would like to know what is resetting it though, possibly acadr15.lsp?
that's got semicolons before it though, doesn't that mean it's not loading?
Just the fact that you found a acaddoc.lsp-file makes me think that there's someone in your office, or has been that has done customizations to autocad, and these could be messing things up. As far as I know, on a completely new install, the acaddoc.lsp file doesn't even exist.
Before editting your acaddoc.lsp file, SAVE A BACKUP copy, that way if something goes wrong you can go "Back to the beginning"
shows how long it is since I used LISP! :lol: Yes, semi colons are comments, not commands.
disregard following comment - stupidity rules!
However, acadm.lsp hasn't.
I did a search for acadr15.lsp and didn't find any file with that name...I'm using AC 2009...
jl:roll:
Does that mean I can delete it?
hmm....I have created an acaddoc.lsp for the sole purpose of making sure my settings are always loaded. So if you don't use anything that is in there, then yes, you can delete it. What you could try is to remove it - change it's name and chuck it somewhere else and then start AutoCAD and see if something is different.
Like I said, there's a reason it's there, that reason could be obsolete though.
Antoher question - can you find the acadm.lsp somewhere? Because I think that is loaded through you acaddoc.lsp
Sure, Here is acadm.lsp :wink:
(defun AcadMappend(startup /)(if(cond((/= T(load"gen/genbas0.lsp" T)) T)((/= T(load"gen/genbas0.ll" T)) T)((/= T(if ge0geniusdir(load(strcat ge0geniusdir"gen/genbas0.lsp") T) T)) T)((/= T(if geniuspd(load(strcat(geniuspd)"gen/genbas0.lsp") T) T)) T)(T nil))(append(list(if startup(car startup) nil)(list(quote acadmstartup)))(cdr startup))(progn(prompt"\nAcadM Error: file genbas0.lsp not loaded.") startup)))(defun genneuzeich()(redraw))(if(=(type *error*) 'SUBR)(setq *error* nil))(if(not special)(defun special(a) a))(defun c:amlayer_con1()(command"_amlayer""_o""con1")(princ))(defun c:amlayer_con2()(command"_amlayer""_o""con2")(princ))(defun c:amlayer_con3()(command"_amlayer""_o""con3")(princ))(defun c:amlayer_hidw()(command"_amlayer""_o""hidw")(princ))(defun c:amlayer_hidn()(command"_amlayer""_o""hidn")(princ))(defun c:amlayer_hlin()(command"_amlayer""_o""hlin")(princ))(defun c:amlayer_dili()(command"_amlayer""_o""dili")(princ))(defun c:amlayer_txt3()(command"_amlayer""_o""txt3")(princ))(defun c:amlayer_cenw()(command"_amlayer""_o""cenw")(princ))(defun c:amlayer_cenn()(command"_amlayer""_o""cenn")(princ))(defun c:amlayer_hatch()(command"_amlayer""_o""hatc")(princ))(defun c:amlayer_vpli()(command"_amlayer""_o""vpli")(princ))(defun c:amlayer_phan()(command"_amlayer""_o""phan")(princ))(defun c:amunit_0()(gensv)(gendimsetdecimals 0)(command"_UNITS" 2 0 1 0 0"_N")(genprompt"xx.")(genun)(princ))(defun c:amunit_1()(gensv)(gendimsetdecimals 1)(command"_UNITS" 2 1 1 1 0"_N")(genprompt"xx.x")(genun)(princ))(defun c:amunit_2()(gensv)(gendimsetdecimals 2)(command"_UNITS" 2 2 1 2 0"_N")(genprompt"xx.xx")(genun)(princ))(defun c:amunit_3()(gensv)(gendimsetdecimals 3)(command"_UNITS" 2 3 1 3 0"_N")(genprompt"xx.xxx")(genun)(princ))(defun c:amunit_4()(gensv)(gendimsetdecimals 4)(command"_UNITS" 2 4 1 4 0"_N")(genprompt"xx.xxxx")(genun)(princ))(princ)
Why not just create a new lisp in notepad with
(setvar "filletrad" 0.75)
Than save and put in your startup suite, or add the folder it is in to your "Support File Search Path" in Options....
not a reply, just added a code tag and a bit of formatting....
(T nil))
(cdr startup))
(redraw))
:lol: I got no idea what that does!
But since it exists, and is loaded every time you start a new drawing I'm assuming your using it somehow, even if you perhaps don't know about it.
So I still say, add the line about filletrad at the end.
Smorales - you'r aboslutetly right. I usually recommend adding settings like this to acaddoc.just becuase it's quite often already there and I think it's easier the fewer documents/lisps you have. but that's just my opinion.
