hosyn Posted July 22, 2014 Posted July 22, 2014 it's possible ctrl-x and ctrl-y embed in lisp routine and how? Quote
pBe Posted July 22, 2014 Posted July 22, 2014 (Defun c:Democopy (/ string 2ClipB) (vl-load-com) (if (setq string (ssget "_:S" '((0 . "TEXT")))) (progn (vlax-invoke (vlax-get (vlax-get (setq 2ClipB (vlax-create-object "htmlfile")) 'ParentWindow ) 'ClipBoardData ) 'SetData "Text" (cdr (assoc 1 (entget (ssname string 0)))) ) (vlax-release-object 2ClipB) ) ) ) (Defun c:Demopaste (/ string 2ClipB txtstring) (vl-load-com) (if (setq string (ssget "_:S" '((0 . "TEXT")))) (progn (setq txtstring (vlax-invoke (vlax-get (vlax-get (setq 2ClipB (vlax-create-object "htmlfile")) 'ParentWindow ) 'ClipBoardData ) 'GetData "Text" ) ) (vla-put-textstring (vlax-ename->vla-object (ssname string 0)) txtstring ) (vlax-release-object 2ClipB) ) ) ) Quote
hosyn Posted July 22, 2014 Author Posted July 22, 2014 pBe It sounds your routine specially for text ,are there for any entity?? Quote
Lee Mac Posted July 22, 2014 Posted July 22, 2014 It sounds your routine specially for text ,are there for any entity?? Try the CUTCLIP / PASTECLIP commands. Quote
hosyn Posted July 22, 2014 Author Posted July 22, 2014 Thanxxxx Mr LEE MAC:) I try (command "copyclip" ) And i don't know what's difference between (command "copyclip" ) and (command "_copyclip" ) and (command ".copyclip" ) and (command "._copyclip" ) ??? and which one is better and why?? Quote
Lee Mac Posted July 22, 2014 Posted July 22, 2014 And i don't know what's difference between (command "copyclip" ) and (command "_copyclip" ) and (command ".copyclip" ) and (command "._copyclip" ) ???and which one is better and why?? AutoCAD Command Prefixes An Introduction to Script Writing (see bullet points) Quote
pBe Posted July 23, 2014 Posted July 23, 2014 pBe It sounds your routine specially for text ,are there for any entity?? Oops my bad. Quote
wal_dab Posted February 12, 2015 Posted February 12, 2015 Thank you pBe : but how to select mutable text rather than one entity selection?? Thank you Quote
pBe Posted February 15, 2015 Posted February 15, 2015 Thank you pBe : but how to select mutable text rather than one entity selection??Thank you Are you wanting to concatenate multiple string values into one? what are you planning to do with the results? paste into a text file? or for a text/mtext entity string value? Quote
wal_dab Posted February 15, 2015 Posted February 15, 2015 Hi i want to select all text and copy their values to clipboard and paste to excel thank you very much Quote
pBe Posted February 16, 2015 Posted February 16, 2015 Hii want to select all text and copy their values to clipboard and paste to excel thank you very much ALL text? in what format? one word or phrase per cell? this is very intriguing, post a cad file and a Excel file which shows the result you want Quote
limfx Posted January 6, 2024 Posted January 6, 2024 text cad file I want to select all text and copy their values to clipboard and paste to excel Quote
BIGAL Posted January 7, 2024 Posted January 7, 2024 (edited) Did you google ? Uses sort on Y so knows the order for excel, I think the example code solution was for multi line text and mtext. May have been Forums/Autodesk. Edited January 7, 2024 by BIGAL 1 Quote
