Are there a way copy and paste via clipboard by lisp?
hosyn
it's possible ctrl-x and ctrl-y embed in lisp routine and how?:?
(Defun c:Democopy (/ string 2ClipB)
 (vl-load-com)
 (if (setq string (ssget "_:S" '((0 . "TEXT"))))
     (vlax-invoke
(vlax-get
  (vlax-get (setq 2ClipB (vlax-create-object "htmlfile"))
	    'ParentWindow
  'ClipBoardData
'SetData
"Text"
(cdr (assoc 1 (entget (ssname string 0))))
     (vlax-release-object 2ClipB)
(Defun c:Demopaste (/ string 2ClipB txtstring)
 (vl-load-com)
     (setq
txtstring (vlax-invoke
	    (vlax-get
	      (vlax-get
		'ParentWindow
	      'ClipBoardData
	    'GetData
	    "Text"
     (vla-put-textstring
(vlax-ename->vla-object (ssname string 0))
txtstring
pBe
It sounds your routine specially for text ,are there for any entity??:unsure:
Try the CUTCLIP / PASTECLIP commands.
Thanxxxx Mr LEE MAC:)
I try
(command "copyclip" )
And i don't know what's difference between (command "copyclip" ) and (command "_copyclip" ) and (command ".copyclip" ) and (command "._copyclip" ) ???
and which one is better and why??
pBe
Oops my bad.
  • 6 months later...
Thank you pBe : but how to select mutable text rather than one entity selection??
Thank you
Thank you
Are you wanting to concatenate multiple string values into one? what are you planning to do with the results? paste into a text file? or for a text/mtext entity string value?
Hi
i want to select all text and copy their values to clipboard and paste to excel
thank you very much
Hi
thank you very much
ALL text? in what format? one word or phrase per cell? this is very intriguing, post a cad file and a Excel file which shows the result you want
  • 8 years later...
text cad file
I want to select all text and copy their values to clipboard and paste to excel
Did you google ? Uses sort on Y so knows the order for excel, I think the example code solution was for multi line text and mtext. May have been Forums/Autodesk.
Edited by BIGAL
  • 1 year later...
 (vl-load-com)
     (vlax-invoke
(vlax-get
	    'ParentWindow
  'ClipBoardData
'SetData
"Text"
 (vl-load-com)
     (setq
	    (vlax-get
	      (vlax-get
		'ParentWindow
	      'ClipBoardData
	    'GetData
	    "Text"
     (vla-put-textstring
txtstring
(Defun c:AClip (/ 2ClipB enam elst objid ss ent1 fldexp1 fldexp2 pt)
 (vl-load-com)
   	(while (null (setq enam (car (nentsel "\nSelect LWPOLYLINE or HATCH: "))))
		(princ "Nothing Selected")
	);while
	(setq elst (entget enam))
	(if (or
		(= (cdr (assoc 0 elst)) "LWPOLYLINE") (= (cdr (assoc 0 elst)) "HATCH") (= (cdr (assoc 0 elst)) "AECC_TIN_SURFACE"))
			(setq objid (vla-get-ObjectId (vlax-ename->vla-object enam)))
			(setq ent1 "%lu2%pr0%ps[, sf]%th44")
			(setq fldexp1 (strcat "%<\\AcObjProp Object(%<\\_ObjId " (itoa objid) ">%).Area " (chr 92)"f " (chr 34) ent1 (chr 34) ">%"))
			(setq ent1 "%lu2%pr3%ps[, ac]%ct8[2.295684113865930E-005]%th44")
			(setq fldexp2 (strcat "%<\\AcObjProp Object(%<\\_ObjId " (itoa objid) ">%).Area " (chr 92)"f " (chr 34) ent1 (chr 34) ">%"))
			(setq fldexp1 (strcat fldexp1 " " (chr 40) fldexp2 (chr 41)))
			(setvar "cmdecho" 0)
			(vlax-invoke
				(vlax-get
					'ParentWindow
					'ClipBoardData
				'SetData
				"Text"
				(strcat fldexp1)
			(setvar "cmdecho" 1)
		(princ "\nSelected Entity is Not a LWPOLYLINE or HATCH.")
	);If
	(setq
		2ClipB nil
		enam nil
		elst nil
		ent1 nil
		objid nil
		ss nil
		fldexp1 nil
		fldexp2 nil
		pt nil)
	(gc)
);AClip
Just giving back.
I altered pBe's lisp to build INSERT FIELDs for either selected LWPOLYLINE or HATCH object and add those to the clipboard.  A paste action will make an MTEXT object with area formatted as both acres and sq. ft.
