pacificus Posted July 21, 2014 Author Posted July 21, 2014 SW part and STEP files for the same problem model: Part1.SLDPRT.zipFetching info... Part1.STEP.zipFetching info... Quote
stevsmith Posted July 22, 2014 Posted July 22, 2014 JD Mather said: Does SolidWorks have T-Splines like Inventor 2015? No. I take it that T-Splines is a new addition to Inventor, or an add-in perhaps? I haven't used inventor for over 3+ years now. Quote
JD Mather Posted July 22, 2014 Posted July 22, 2014 pacificus said: SW part and STEP files for the same problem model: Well, I have to give up and move on - I could not find anything wrong. Quote
JD Mather Posted July 22, 2014 Posted July 22, 2014 stevsmith said: I take it that T-Splines is a new addition to Inventor, .... A game changer. Quote
SLW210 Posted July 22, 2014 Posted July 22, 2014 Why nut run Win 8 as a dual boot? That might solve some of your problems with the computer and virtualbox. Quote
pacificus Posted July 22, 2014 Author Posted July 22, 2014 JD Mather said: Well, I have to give up and move on - I could not find anything wrong. Thank you very much for checking the model, I appreciate it. I am now fairly confident that ALGOR is corrupted or broken (files missing). I need to find the original disc containing it (image file) but am not confident I will be able to. I have now been able to analyse a very basic solid model in SW Simulation, but still not the original (the model in the files I uploaded). Quote
pacificus Posted July 22, 2014 Author Posted July 22, 2014 SLW210 said: Why nut run Win 8 as a dual boot? That might solve some of your problems with the computer and virtualbox. I am considering that but would need to sort a free HDD out in order to do so. I'll stick with SW for this project as I'm confident ALGOR is broken and not SW, so no need to fix Pro/e. I've used ALGOR in VB before with no problem whatsoever. Quote
