7o7 Posted July 22, 2014 Share Posted July 22, 2014 There is something wrong with your file 221.idw.dwg , you "audit" it (Files > Drawing Utilities > Audit) and will be fine. About the sorting, change the defun sort to this: (defun sort(l) (mapcar 'cadr (vl-sort (mapcar '(lambda(x) (list (atoi (vl-list->string (vl-remove-if-not '(lambda(y) (<= 48 y 57)) (vl-string->list x)))) x)) l) '(lambda(m n) (< (car m) (car n))))) ) And what you want to set spacing for? we don't know the dimension of inserted file frame, we can only put them side by side. Quote Link to comment Share on other sites More sharing options...
