Lee Chu Chu Posted July 16, 2014 Posted July 16, 2014 I have been getting this error in autocad 2015 but not in 2014 for some reason. Cannot invoke (command) from *error* without prior call to (*push-error-using-command*). Converting (command) calls to (command-s) is recommended. Can anybody please help me understand what this means? I have been using this code from Afralisp (defun c:drawline () ;define function (initerr) ;intit error (setvar "cmdecho" 0) ;reset variables (setvar "osmode" 32) (command "undo" "m") ;set mark (setq pt1 (getpoint "\nPick First Point: ")) ;get points (setq pt2 (getpoint pt1 "\nPick Second Point: ")) (command "LAYER" "M" "2" "") ;change layer (command "Line" pt1 pt2 "") ;draw line (setq pt3 (getpoint pt2 "\nPick Third Point: "));get 3rd point (setvar "osmode" 0) ;reset snap (command "Line" pt2 pt3 "") ;draw line (reset) ;reset variables (princ) ) (defun error() ;load function (prompt "\nGlobal Error Trap Loaded") ;inform user (princ) );defun ;;;*========================================================== (defun initerr () ;init error (setq oldlayer (getvar "clayer")) ;save settings (setq oldsnap (getvar "osmode")) (setq oldpick (getvar "pickbox")) (setq temperr *error*) ;save *error* (setq *error* trap) ;reassign *error* (princ) );defun ;;;*=========================================================== (defun trap (errmsg) ;define trap (command nil nil nil) (if (not (member errmsg '("console break" "Function Cancelled")) ) (princ (strcat "\nError: " errmsg)) ;print message ) (command "undo" "b") ;undo back (setvar "clayer" oldlayer) ;reset settings (setvar "blipmode" 1) (setvar "menuecho" 0) (setvar "highlight" 1) (setvar "osmode" oldsnap) (setvar "pickbox" oldpick) (princ "\nError Resetting Enviroment ") ;inform user (terpri) (setq *error* temperr) ;restore *error* (princ) );defun ;;;*=========================================================== (defun reset () ;define reset (setq *error* temperr) ;restore *error* (setvar "clayer" oldlayer) ;reset settings (setvar "blipmode" 1) (setvar "menuecho" 0) (setvar "highlight" 1) (setvar "osmode" oldsnap) (setvar "pickbox" oldpick) (princ) );defun You can find the code here: http://www.afralisp.net/autolisp/tutorials/error-trapping.php Quote
MSasu Posted July 16, 2014 Posted July 16, 2014 Please try to replace this part (defun trap (errmsg) ;define trap (command nil nil nil) (if (not (member errmsg '("console break" "Function Cancelled")) ) (princ (strcat "\nError: " errmsg)) ;print message ) (command "undo" "b") ;undo back with: (defun trap (errmsg) ;define trap ([color=magenta]command-s[/color]) (if (not (member errmsg '("console break" "Function Cancelled")) ) (princ (strcat "\nError: " errmsg)) ;print message ) ([color=magenta]command-s[/color] "undo" "b") ;undo back Is recomended to use said function in error traps and seems that AutoCAD 2015 is enforcing stronger this rule; from help: The command-s function is a variation of the command function which has some restrictions on command token content, but is both faster than command and can be used in *error* handlers due to internal logic differences. Quote
Lee Chu Chu Posted July 16, 2014 Author Posted July 16, 2014 Thanks that seemed to do the trick. I have another question if you dont mind. I am using this as a test so make sure that you are aware that if this works on this particular function, it should work for the rest of my functions. I can't seem to get the error trapping to work. Could you please help me out? (defun c: trec() (initerr) (setvar "clayer" "text_25") (setvar "osmode" 2) (command "undo" "m") (command "rectang") (reset) (princ) );defun For some reason, when this function is called up, the variables dont get set so it the original settings before this command is called up is still there. Could you please help me figure out why the clayer and osmode doesnt get set for this? Quote
MSasu Posted July 16, 2014 Posted July 16, 2014 The RESET function isn't reached due to the way you called the command. This will ensure that AutoLISP is resumed: ... (command "[color=red]_[/color]rectang") [color=red] (while (> (getvar "CMDACTIVE") 0)[/color] [color=red] (command pause)[/color] [color=red] )[/color] (reset) ) Quote
Lee Chu Chu Posted July 16, 2014 Author Posted July 16, 2014 Thank you so much for your help. Now everything works. Quote
