Recently upgraded to Civil 3D 2015 from 2013 but am having trouble using one of my most used AutoLISP commands to connect a string of points (connectpts)
When I load the command I get the following error message;
"; error: Automation Error. Problem in loading application"
Any ideas out there?
This is file;
;|Platform: AutoCAD Civil 3D
Routine to draw 3dPoly between points with identical descriptions, in ascending Pt# order.
by Jeff Mishler, July 25, 2007. Tested only in C3D2008. Type (vl-load-com) at command prompt first.
(vl-load-com)
(defun c:Connectpts (/ appstr coords desc grps pline point point#s points pt qbldr ss tmpgrp vrsn )
(setq vrsn (vlax-product-key))
(cond ((vl-string-search "R16.2" vrsn)(setq appstr "3.0"));;2006
((vl-string-search "R17.0" vrsn)(setq appstr "4.0"));;2007
((vl-string-search "R17.1" vrsn)(setq appstr "5.0"));;2008
((vl-string-search "R17.2" vrsn)(setq appstr "6.0"));;2009
((vl-string-search "R18.0" vrsn)(setq appstr "7.0"));;2010
((vl-string-search "R18.1" vrsn)(setq appstr "8.0"));;2011
((vl-string-search "R18.2" vrsn)(setq appstr "9.0"));;2012
((vl-string-search "R19.0" vrsn)(setq appstr "10.0"));;2013
((vl-string-search "R19.1" vrsn)(setq appstr "11.0"));;2014
((vl-string-search "R20.0" vrsn)(setq appstr "12.0"));;2015
(t (alert "This version of C3D not supported!"))
(if (and appstr
(or *acad*
(setq *acad* (vlax-get-acad-object))
(or *AeccApp*
(setq *AeccApp* (vla-getinterfaceobject *acad*
(strcat "AeccXUiLand.AeccApplication." appstr)))
(or *AeccDoc*
(setq *AeccDoc* (vlax-get *AeccApp* 'ActiveDocument))
(setq ss (ssget ":S:E" '((0 . "AECC_COGO_POINT"))))
(setq pt (vlax-ename->vla-object (ssname ss 0))
desc (vlax-get pt 'RawDescription)
grps (vlax-get *AeccDoc* 'PointGroups)
tmpgrp (vlax-invoke grps 'Add "__TEMP__")
(setq qbldr (vlax-get tmpgrp 'querybuilder))
(vlax-put qbldr 'IncludeRawDescriptions desc)
(if (> (length (setq points (vlax-get tmpgrp 'Points))) 1)
(setq point#s (vl-sort points '
(setq points (vlax-get *AeccDoc* 'Points))
(foreach pt# point#s
(setq point (vlax-invoke points 'Find pt#))
(setq coords (append coords (list (vlax-get point 'Easting)
(vlax-get point 'Northing)
(vlax-get point 'Elevation)
(setq pline (vlax-invoke (vla-get-modelspace *AeccDoc*) 'Add3dPoly coords))
(vla-put-layer pline (vlax-invoke *aeccdoc* 'getvariable "Clayer"))
(vlax-invoke qbldr 'clear)
(vlax-invoke grps 'remove "__TEMP__")
Pretty sure had same problem last week and I had to do a Repair on CIV3d, it does not find the AeccXuland version properly.
Just run the version part of your code as a check if it errors then Repair required.
(vl-load-com)
(princ appstr) ; if not display then  problem
