drmane Posted July 8, 2014 Posted July 8, 2014 Hi everyone, Could someone help me to create an action in AC2010 where I could draw a box. I want to be able to enter the width and height of the box every time I run this action. This is to help us draw doors which come in different sizes. Any help is much appreciated. Thanks, Tom Quote
Tiger Posted July 8, 2014 Posted July 8, 2014 Soo... you're looking for the RECTANGLE command? Command: REC RECTANG Specify first corner point or [Chamfer/Elevation/Fillet/Thickness/Width]: Specify other corner point or [Area/Dimensions/Rotation]: d Specify length for rectangles : Specify width for rectangles : Quote
drmane Posted July 8, 2014 Author Posted July 8, 2014 Soo... you're looking for the RECTANGLE command? Command: REC RECTANG Specify first corner point or [Chamfer/Elevation/Fillet/Thickness/Width]: Specify other corner point or [Area/Dimensions/Rotation]: d Specify length for rectangles : Specify width for rectangles : Hi Tiger, Many thanks for your quick response. I am not sure this works as when I draw using rec command I end up drawing a filled rectangular. All I need is a box with user specified dimensions that I can explode in the next step of the action. Ideally the action would run like this: BOX = DOOR 1. Draw a box ( user specifies width and height) 2. Explode the box 3. Offset the lines by user specified values ( these will be door rails, styles and mullions) 4. Prepare the box with offset rails etc for trimming. Please, let me know if I missed anything from you advice. Also, I have attached a typical drawing that we keep making on a daily basis. It should give you a good idea of the end product action I would love to be able to record. Many thanks for your help. Tom Quote
JerryG Posted July 8, 2014 Posted July 8, 2014 Type "rec" - type "W" for width - set it to 0 now type "T" for thickness and set it to 0 also. Now you should be able to draw a simple box. Type "Rec" again. now select a random point on the screen and click. You will see a rectangle that varies in height and width as you move your mouse. To create your desired Width and Height type "@3,6.5" then hit enter. This would create a 3 foot wide door by 6'-6" height. The @ symbol is simply stating that "AT" the point you clicked will be the start point of your box. Now that you have your Rectangle created offset it your desired width - then explode so you can add your detail etc. Quote
drmane Posted July 8, 2014 Author Posted July 8, 2014 Type "rec" - type "W" for width - set it to 0now type "T" for thickness and set it to 0 also. Now you should be able to draw a simple box. Type "Rec" again. now select a random point on the screen and click. You will see a rectangle that varies in height and width as you move your mouse. To create your desired Width and Height type "@3,6.5" then hit enter. This would create a 3 foot wide door by 6'-6" height. The @ symbol is simply stating that "AT" the point you clicked will be the start point of your box. Now that you have your Rectangle created offset it your desired width - then explode so you can add your detail etc. Thanks JerryG, Great! This does work. The only thing is how do I record the action so that it allows the user to stop and input the sizes? Quote
JD Mather Posted July 8, 2014 Posted July 8, 2014 I recommend that you start learning about Blocks (after learning basics like Rectangle). Then start researching Dynamic Blocks. Quote
BIGAL Posted July 9, 2014 Posted July 9, 2014 I agree with JD above but if you draw lots of doors then look at the world of programing with lisp Pick a pt Door type Enter W H panel1 W H kick H panels how many Mullion width Glass type door is now drawn This is not doors but you can pick style from say a selection. Quote
