Lee Chu Chu Posted July 8, 2014 Share Posted July 8, 2014 I want a command reactor to be able to activate inside a function however I am not sure if command reactors work with a user defined command or function. For an example, I want to be able to get the reactor to work on some (defun c:drawsomething () ....) and I want it to look for when the command drawsomething is called up? Can someone please point me in the right direction. Quote Link to comment Share on other sites More sharing options...
7o7 Posted July 8, 2014 Share Posted July 8, 2014 Can you explain more clearly with a dwg file and some lisp code? Quote Link to comment Share on other sites More sharing options...
