obscurejack Posted July 6, 2014 Posted July 6, 2014 Hello! I'm a noob in rhino and I found some problems by making a polysurface solid: my problem is that I have two elements: a sphere and a twisted pyramid, joined by boolean union which I can't offset to add an internal thicken. when I do it (with "solid" option activated) it just creates a polysurface inside it, without creating an emptiness in it. I can't even make a boolean difference, boolean 2 objects or neither a solid subtraction that work with polysurfaces which surfaces do not intersect each other. Indeed, when I make a section to see how it is inside there's no hole but only the sectioned edges of the offset polysurf. H E L P!!!! Quote
SEANT Posted July 7, 2014 Posted July 7, 2014 Rhino has a surface focus. Thus, some of the concepts that pertain to "Solids" in other software applications are not present in Rhino. One such concept is internal hollows - or, put another way - surfaces/surface incorporation without direct connection. The typical way to deal with this is to add a direct connection. See attached image. I was able to hollow out that figure by providing a minimal direct connection in an inconspicuous spot. Quote
obscurejack Posted July 7, 2014 Author Posted July 7, 2014 thank you very much, I already solved the problem with the same tecnique but in a different way ^^ Quote
SEANT Posted July 7, 2014 Posted July 7, 2014 obscurejack said: . . . . I already solved the problem . . . . ^^ That's all that matters. Quote
