adlamabad Posted July 3, 2014 Posted July 3, 2014 Good evening all, I am trying to make an iPart using iLogic rules and I'm stuck. The part (put simply) is a solid box with a rectangular hole running right through it, slightly off centre. My sketch includes an 'X' dimension (which is also d3 and d4), that I would like to be determined by what I input as 'ApertureWidth' and 'ApertureHeight' Below is what I have written as an iLogic rule, however the 'X' dimension is not behaving as I like ie it is always 125mm. This is my first attempt at iLogic so I'm sure it's something simple but I can't see it. Any help appreciated If ApertureHeight=100 AndAlso ApertureHeight If ApertureHeight=275 AndAlso ApertureHeight If ApertureHeight=1025 AndAlso ApertureHeight If ApertureHeight=1525 AndAlso ApertureHeight If ApertureHeight=2025 AndAlso ApertureHeight If ApertureHeight=2525 AndAlso ApertureHeight If ApertureHeight>=75 And ApertureWidth>=100 AndAlso ApertureHeight If ApertureHeight>=75 And ApertureWidth>=275 AndAlso ApertureHeight If ApertureHeight>=75 And ApertureWidth>=1025 AndAlso ApertureHeight If ApertureHeight>=75 And ApertureWidth>=1525 AndAlso ApertureHeight If ApertureHeight>=75 And ApertureWidth>=2025 AndAlso ApertureHeight If ApertureHeight>=75 And ApertureWidth>=2525 AndAlso ApertureHeight Quote
Faouweb Posted July 4, 2014 Posted July 4, 2014 Hi, Attach your IPT file here. I have tried to learn ILogic, I will see if I can help you. Quote
adlamabad Posted July 16, 2014 Author Posted July 16, 2014 Hi,Attach your IPT file here. I have tried to learn ILogic, I will see if I can help you. Hi mate, I know it has been a while, been very busy at work recently. I have attached the ipt and as you can see I'm not getting far Signature i-Part [STAINLESS].ipt Many thanks Quote
adlamabad Posted July 16, 2014 Author Posted July 16, 2014 I think I've sorted it out now after all, I was missing all the " speech marks " If ApertureHeight >= "75" And ApertureWidth >= "100" And ApertureWidth X= "125" End If If ApertureHeight >= "75" And ApertureWidth>= "275" And ApertureWidth X= "135" End If If ApertureHeight >= "75" And ApertureWidth >= "1025" And ApertureWidth X= "145" End If If ApertureHeight >= "75" And ApertureWidth >= "1525" And ApertureWidth X= "155" End If If ApertureHeight >= "75" And ApertureWidth>= "2025" And ApertureWidth X= "165" End If If ApertureHeight >= "75" And ApertureWidth >= "2525" And ApertureWidth X= "175" End If If ApertureHeight = "50" And ApertureWidth >= "100" And ApertureWidth X= "137.5" End If If ApertureHeight = "50" And ApertureWidth>= "275" And ApertureWidth X= "137.5" End If If ApertureHeight = "75" And ApertureWidth >= "1025" And ApertureWidth X= "145" End If If ApertureHeight = "75" And ApertureWidth >= "1525" And ApertureWidth X= "155" End If If ApertureHeight = "75" And ApertureWidth>= "2025" And ApertureWidth X= "165" End If If ApertureHeight = "75" And ApertureWidth >= "2525" And ApertureWidth X= "175" End If Quote
Faouweb Posted July 17, 2014 Posted July 17, 2014 I did something almost similar to your drawing with holes, I think you can use Select Case as you can see in this topic: http://www.cadtutor.net/forum/showthread.php?84039-Ilogic-need-help-with-quot-Case-quot Quote
