Hello,
I am working on a tunnel alignment. I have to draw multiple closed 3d polylines from AutoCAD Points (which form the tunnel sections from the excavation). I use the 3POLY command and then the option "PN. Is it possible to write a script (or a lisp routine) that repeats this process?
For example, I wrote this script
3POLY
'PN
1-10,1
(1 row blank)
3POLY
'PN
11-20,11
It draws the first closed 3dpoly (from point numbers 1 to 10 and closes to 1)
but it not continues to second 3poly.
Thank you in advance
I get unknown command for 3poly it may be a lisp etc then task can be done differently, other way is dump pts into excel and make a script of the points to be connected using 3dpoly x,y,z x,y,z etc.
Did you mean 3dpoly ?
Bigal thank you for your reply,
I'm sorry for the inconvenience. You are right, I mean 3dpoly command. I've already tried the solution you suggest (i made a script with the points like the image) but it is no convenient for me.
I have already imported all the points from a txt file. The most important aspect of the solution I seek is to draw these 3d polylines using the point numbers and not by using coordinates.
I had a Google your close it is probably your script, I would still look at excel and write a macro to work out the start and end of point groups. Will see if I can do.
not tested
3dpoly
'pn 1-35
C
3dpoly
'pn 36-72
C
