thbaiju Posted July 3, 2014 Posted July 3, 2014 Hi all, here Iam attaching a drawing which I need to edit the text. If I explode the block all are coming with lines and arc...do you have any solution Test.dwgFetching info... Quote
steven-g Posted July 3, 2014 Posted July 3, 2014 The text inside the block is made up of polylines. I would imagine you got this block from another company, this is their way of being funny to stop anyone copying the details easily, I think you may have to redraw anything you want to use including the text. Even the hatches have been exploded. I used to work with someone who did that with everything even for our own drawings. Quote
dbroada Posted July 3, 2014 Posted July 3, 2014 I wonder if this at some time has been converted from a pdf. Either way, as steven says, redrawing it looks to be the easiest way. Quote
