Morning,
I'm working on a block with a few variables I'm trying to synchronize. I've worked dynamic blocks in the past for mirror imaging stretches, but is there a way I could sync it so when I rotate Rotation Parameter 1 10 degrees, that Rotation Parameter 2 and Rotation Parameter 3 rotate the same 10 degrees?
Thanks for the help!
Do you want an equal angle, or an equal rotation?
I believe either is possible, the later requiring a few lines on a “hidden” layer.
It would be equal rotation. The RP2 and RP3 are starting at 30 degrees while the RP1 is starting at 0. but they will all rotate clockwise, reducing the 30 degree angles and increasing the 0 degree angle.
maybe a before and after drawing would help
Very useful dbroada! Thanks. I will work with the independent rotation bases and provide the example later today.
