If I get a file with a hatch I'd like to save as my own, is there a quick way to do this (besides for contacting the sender and asking for their PAT or obsessively searching online?)
I can see in Properties that the hatch is called 020 and it's under Custom, but when I try to Match Props to get it to replicate it just turns out solid. Any ideas?I'm attaching the file, the hatch I want is for the mirror. Thanks!
mirror hatch question.dwgFetching info...
hugha-
PERFECT!! (I'm excited that I managed to save a LISP and everything, too :) )
Additional question- even if my LISPs are in the support file paths under options, do I still need to do APPLOAD every time I want to use one?
Thank you so much for the GETPAT idea!
Hi
You can also Drag-and-Drop .LSP files onto your workspace to load them, or place them in your Startup Suite.
Could you explain the Startup Suite thing?
If the LISPs are already in my Support Filepaths under Options, it's not enough?
