mjavila Posted June 26, 2014 Posted June 26, 2014 Hello People. Yesterday i downloaded AutoCAD CIVIL 3D 2015 in my Dell with windows 8. I was currently working with civil 3d 2013 and I appeared errors shareability with windows 8. A result of that I decided to download and install civil 3d 2015 by the shareability of windows 8. But when you start the application the pointer in the work area repeats me and gets stuck. as the picture shows. will be for some setting you need to disable or enable?. my dell have i7 4th generation. 8Gb RAM and 2gb Video Card. please help me!.. thanks..sorry for my english Quote
edwinprakoso Posted June 27, 2014 Posted June 27, 2014 AutoCAD 2015 has many issues with graphic card. You may be able to turn off the hardware acceleration to fix the display problem. However, you are working with Civil3D. You will not be happy with the performance. Type 3DCONFIG and turn off the hardware acceleration. Quote
RobDraw Posted June 27, 2014 Posted June 27, 2014 edwinprakoso said: AutoCAD 2015 has many issues with graphic card. Not good when for a release that was supposed to improve performance. Quote
Organic Posted June 28, 2014 Posted June 28, 2014 RobDraw said: Not good when for a release that was supposed to improve performance. The same could be said about almost every release of Civil 3D though. Quote
mjavila Posted July 1, 2014 Author Posted July 1, 2014 thanks edwinprakoso.. the command is GRAPHICSCONFIG. then turn off hardware acceleration. Quote
