Sheet Metal Flat Pattenrn (Print with Bend Lines)
Placed a Flat Pattern of folded part into a drawing but no bend lines visible. Would like to print out pattern full size with bend lines with a view to using it as a template. Can this be done? If so could someone point me in the right direction please.Best regards to everyone Jake8090.
Edited by Jake8090
Incorrect spelling
I don't have Inventor open right now, but from memory, try this -
double click in the view and a dialog box should pop up with one of the Options to display bend lines.
Found it. Thanks JD. Beginning to realise that somewhere in those dialogue boxes there is an answer. Only get 2/3 hours a day but getting there slowly and enjoying the learning. (keeping Dimentia at bay)Jake8090
