Lisp to find regions
highrez2
Looking for a solution to search thousands of dwg's to see if they have a region in them. And if so display this list or save the list for later use.
Create a list of files to be investigated using a BAT file with statement below:
DIR /b *.DWG > MyDrawingsList.SCR
After build from it a script like below (one line for each file) - adjust the colored parts:
_OPEN "[color=blue]C:\MyDrawings\Drawing1st.dwg[/color]" (if (ssget "_X" '((0 . "REGION"))) (progn (setq fis (open "[color=magenta]C:\\RegionQueryResults.txt[/color]" "a")) (write-line "[color=blue]Drawings1t.dwg[/color]" fis) (close fis))) _CLOSE
_OPEN "[color=blue]C:\MyDrawings\Drawing2nd.dwg[/color]" (if (ssget "_X" '((0 . "REGION"))) (progn (setq fis (open "[color=#ff00ff]C:\\RegionQueryResults.txt[/color]" "a")) (write-line "[color=blue]Drawing2nd.dwg[/color]" fis) (close fis))) _CLOSE
;end of script
Use Excel to speed-up the script build.
Thanks,
The BAT file made the SCR file but it looks like it will only search the directory it is in... Is that correct? can I replace DIR with //SERVER_NAME/ How can I handle searching subfolders?
Code:
[color=blue]//SERVER_NAME/[/color] /b *.DWG > MyDrawingsList.SCR
Edited by highrez2
Thanks the list works great.
With my list being quite large 2726 lines (ouch), how do I export the Excel file to create the SCR file?
Or is there another way to report witch files have regions in them?
To offer an alternative, load this function and then load and run the following:
(defun c:findregions ( / f )
   (setq f [color=red]"C:\\RegionResults.txt"[/color]) ;; Output file
   (LM:odbx
      '(lambda ( x / r )
           (vl-catch-all-apply
              '(lambda nil
                   (vlax-for l (vla-get-layouts x)
                       (vlax-for o (vla-get-block l)
                           (if (= "AcDbRegion" (vla-get-objectname o))
                               (progn (setq r t) (exit))
           (if r
               (if (setq d (open f "a"))
                   (progn (write-line (vla-get-name x) d) (close d))
                   (prompt (strcat "\nUnable to open " f))
       nil nil
   (if (setq f (findfile f))
       (startapp "notepad" f)
       (prompt "\nNo regions found in any drawing.")
(vl-load-com) (princ)
Thanks again lee I will try this out once the first method is done.
