Gordon-Citrine Posted June 17, 2014 Posted June 17, 2014 If I select certain images sizes I get a corrupted jpeg plot - see attached. The image size plotted was originally 7027 x 4842 pixels = A2; reducing this to 4825 x 3039 worked fine. I suspect it may be something to do with my graphics card (AMD Radeon R9 270) as I have experienced similar with other software too, where the rendered image size was 4606 x 4606 pixels, and I had to render 4611 x 4611 then resize them in Photoshop back to 4606 x 4606). Display drivers are up to date. Any ideas much appreciated, thanks Quote
edwinprakoso Posted June 18, 2014 Posted June 18, 2014 Just guessing, but if you turn off background plotting... is the problem remains? I found that many times background plotting causing some issues. Quote
