Comatosis Posted June 17, 2014 Share Posted June 17, 2014 Is there a command (or a set thereof) I need to input in order to be able to use the Raster Design features in AutoCAD? I've done it successfully before, but I don't remember what I did to get it to work. I have a PDF that I've saved down as a TIFF image and imported to my drawing via the Raster menu, but despite the fact that my Raster Snap on, AutoCAD does not want to recognize any of the edges/corners I want to snap to even though the picture is decent quality (i.e. the line work is unambiguous, non-fuzzy/noisy, etc.). Should I save to jpeg or another format instead? I prefer tiffs because (to my knowledge) there is no compression involved therefore no potential loss of image quality. Thanks Quote Link to comment Share on other sites More sharing options...
Comatosis Posted June 17, 2014 Author Share Posted June 17, 2014 Also, I'm specifically using the raster-related commands (such as Vectorize Polyline/Rectangle, etc.). All I want to do is trace the raster image onto vector format, i.e. what Raster Design was basically made to do. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted June 17, 2014 Share Posted June 17, 2014 It's been a long time since I've used Raster Design but I believe that even though the menus may present that you have to launch it with the RD shortcut in order for the commands to be recognized. Are you to start the command without the unknown command error? Quote Link to comment Share on other sites More sharing options...
Comatosis Posted June 17, 2014 Author Share Posted June 17, 2014 I used to get that, but I managed to fix it by making the correct changes. My only problem at the moment seems to be that it doesn't want to recognize any raster snap points. It will "subtract" raster data from the image and replace it with the appropriate vectors correctly, but I'm simply not getting the option to snap onto the "pixels" I want to (or any pixels for that matter). I made sure to change the image depth to bitonal per the Autodesk website and everything; no dice. I ended up tracing over the lines with regular polylines and I got what I needed, but I'm still intrigued as to why it won't snap, heh. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted June 17, 2014 Share Posted June 17, 2014 Sorry, like I said, it's been a long time. I got nothing else for you. Quote Link to comment Share on other sites More sharing options...
sah Posted May 20 Share Posted May 20 i have the same issue. did u manage to solve it? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted May 21 Share Posted May 21 Not sure Imageattach works in Bricscad draw line from snapped corner. IMAGEFRAME on or off. Maybe a setvar somewhere. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted May 21 Share Posted May 21 The help file for Raster Snap explains that there could be interference from other applications as well as Raster Snap could interfere with other applications. More information on your image might be helpful. Can you post the image here? Quote Link to comment Share on other sites More sharing options...
Steven P Posted May 21 Share Posted May 21 Are you the same as the OP here, and converting PDF to TIFF, in which case if you can import as a PDF, right click and convert. If the PDF is from new up to date software it should convert OK. Suspect that if the TIFF is scanned rather than converted then it will just see the image as a series of pixels and won't snap, likewise if converted from an older PDFs to TIFF. Older PDFs were saved as images rather than vectors so can't snap to them. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted May 21 Share Posted May 21 10 hours ago, BIGAL said: Not sure Imageattach works in Bricscad draw line from snapped corner. IMAGEFRAME on or off. Maybe a setvar somewhere. 2 hours ago, Steven P said: Are you the same as the OP here, and converting PDF to TIFF, in which case if you can import as a PDF, right click and convert. If the PDF is from new up to date software it should convert OK. Suspect that if the TIFF is scanned rather than converted then it will just see the image as a series of pixels and won't snap, likewise if converted from an older PDFs to TIFF. Older PDFs were saved as images rather than vectors so can't snap to them. This isn't exactly AutoCAD, it's one of the free toolsets. Raster Design Toolset in Autodesk AutoCAD | Features It's been a few months since I used it, if I recall, you use the Raster Tools insert and the image has to be bitonal (you can make it one with the Raster Tools Edit>Process Image). Quote Link to comment Share on other sites More sharing options...
