I have created a new multileader with the settings that the multileader type is "block" so that the end of the leader will have a detail bubble on the end, my problem I am running into is the text size inside that bubble is too small, how do i adjust the text size with keeping the bubble the original size? I have the bubble the size I want it at by adjusting the scale to 10", anybody have an idea what to do?
I found the solution to my answer by stumbling around in the quick proprieties in the block editor, not sure if its the best way to adjust the size, but has worked for now
