Vagulus Posted June 13, 2014 Posted June 13, 2014 I need to extrude this shape 0.75" away. Inventor does not recognize it. The slots I can extrude, but I don't want to - yet. Why not the full shape? Thanks 6-119 Boom Swing Bearing for a Power Crane.iptUnavailable Quote
Raygers Posted June 14, 2014 Posted June 14, 2014 Always check around the profile to see that there are no irregularities such as overlapping curves etc. You had a couple that should have been trimmed back, after that it extruded no problem. Quote
Vagulus Posted June 14, 2014 Author Posted June 14, 2014 Ah Hah! Forget not thine magnification. Thanks Quote
JD Mather Posted June 14, 2014 Posted June 14, 2014 (edited) Why are there dimensions on your sketch that aren't in the book? You can reduce sketch clutter by using Equal (=) constraints. Dimension same as in book as these dimensions can later be retrieved when creating 2D drawings. (and trim construction lines) Edited June 14, 2014 by JD Mather Quote
