John1951 Posted June 5, 2014 Share Posted June 5, 2014 Hello I haven t been able to find an answer by searching the forum so I am starting this topic although it may have been answered before. I am trying to create a volume grid map showing cut fill elevation differences at the grid corners and labels in each grid square stating how much cut fill is in that square. I created 2 tin surfaces, Existing Ground Surface and As Made Surface after excavation. I then created a Tin Volume Surface. I closed the EG surface and the As Made Surface leaving only the Tin Volume Surface visible on screen. Next I defined and turned on the grid. Finally I turned on the Levels layer, showing the depth of excavation in shades of blue. Now I am stuck. I am using Autocad Civil 3D 2009 and XP. Any help would be very welcome now Thank You John Quote Link to comment Share on other sites More sharing options...
Tiger Posted June 5, 2014 Share Posted June 5, 2014 Since you already have a volume surface, shouldn't a Surface Label that shows elevation do the trick? You can place them in a grid fashion and customize the text on the label pretty easy. Quote Link to comment Share on other sites More sharing options...
John1951 Posted June 8, 2014 Author Share Posted June 8, 2014 Hello After reading your post I learned to add elevation labels to my volume surface at the grid intersections. I attached a jpg with some of the results. Now all I need to do is add cut/fill amounts to each grid square. Is this possible? Thanks very much John Quote Link to comment Share on other sites More sharing options...
