Vagulus Posted June 5, 2014 Share Posted June 5, 2014 I have an extrusion problem. Hover the cursor over Sketch 6 in the IPT file. My plan was to extrude (cut) areas A & B 25mm into the part. Problem is that I cannot select these areas by themselves. Why not and how can I fix this? Thanks _Extrude_Selection_Problem.ipt Quote Link to comment Share on other sites More sharing options...
JD Mather Posted June 5, 2014 Share Posted June 5, 2014 Something like this? _Extrude_Selection_Problem.ipt Quote Link to comment Share on other sites More sharing options...
Vagulus Posted June 5, 2014 Author Share Posted June 5, 2014 Something like this? I see you got it to work, but I can't figure out what you did. What was (were) the step(s) I missed. Thanks Quote Link to comment Share on other sites More sharing options...
JD Mather Posted June 5, 2014 Share Posted June 5, 2014 If you investigate the sketch closely - you should see what I did, but I recommend you toss this one and start over as it is not modeled logically. Quote Link to comment Share on other sites More sharing options...
