I have a bunch of lisp in a folder on a network with an edited acaddoc.lsp in the>
Support file search path
Trusted Location in the files ACADs option.
I've recently upgraded to 2015 and it intermittently says:
AutoCAD menu utilities loaded.; error: Automation Error. File system error
This message only appears on some drawings. Other drawings the list of scripts in the acaddoc.lsp loads up no problem.
Anybody else experiencing this?
EDIT: Same setup was working in 2013
Edited by 3dwannab
  • 4 weeks later...
It ended up that it was a script that loaded up at the start which caused the problem. Once the script was found and fixed it, I never had this problem again.
A good idea is to post the fix details for any one else I know I have to keep adding version numbers to some of my code
(setq vrsn (vlax-product-key))
((vl-string-search "R17.2" vrsn) (setq appstr "6.0")) ;09
((vl-string-search "R18.0" vrsn) (setq appstr "7.0")) ;10
((vl-string-search "R18.1" vrsn) (setq appstr "8.0")) ;11
((vl-string-search "R18.2" vrsn) (setq appstr "9.0")) ;12 ?
((vl-string-search "R19.0" vrsn) (setq appstr "10.0")) ;13
; 14 ???
; 15 ???
