ben_vk Posted June 3, 2014 Posted June 3, 2014 Hi Guys, We have been supplied over 150 dwg files and I have been assigned the task of exporting them all to PDF. Is there a batch processor that is capable of doing this task? I can see software that will cost $99 and hopefully be able to do it, but im hoping to learn how to do it some other way (if possible!) Has anyone been down this path before and been able to do it? Thanks Quote
ben_vk Posted June 3, 2014 Author Posted June 3, 2014 I posted this in AutoCAD Customisation, but think the question may belong here... We have been supplied over 150 dwg files and I have been assigned the task of exporting them all to PDF. Is there a batch processor that is capable of doing this task? I can see software that will cost $99 and hopefully be able to do it, but im hoping to learn how to do it some other way (if possible!) Has anyone been down this path before and been able to do it? Thanks Quote
gazza_au Posted June 3, 2014 Posted June 3, 2014 Have you got Acrobat X Pro at work? Convert AutoCAD files in batches Choose Adobe PDF > Batch Conversion. Specify your preferences for layers, page size, plot style, and output PDFs. Click Conversion Settings to specify the Acrobat PDFMaker settings. In the DWG List, do any of the following: Click Add Folder or Add Files, and then specify the folder or files. To load a previously saved list of files, click Append List, and then specify the list. As needed, expand individual files and select or deselect the items you want, such as model space and layouts. To exclude or include all model space, click the associated buttons. To exclude a file from the conversion, deselect the file box. As needed, select or deselect all of the files in the list, change the order of the files, remove files, or clear the list. To show the complete file paths, select Expand File Name(s). To save the DWG list for later use, click Save List. This action saves the list in its current state, including the file order and file selections. You can retrieve this list at any time by clicking Append List. [*]Click Convert. [*]Once the conversion is finished, you can click Save Details to save a log file of the conversion. Quote
gazza_au Posted June 3, 2014 Posted June 3, 2014 This link might help also. http://www.cadtutor.net/forum/showthread.php?71564-Mass-dwg-to-pdf-conversion Gazza Quote
asos2000 Posted June 3, 2014 Posted June 3, 2014 Is not PUBLISH do that task? Search on net for this progran "AcroPlot" Quote
ben_vk Posted June 3, 2014 Author Posted June 3, 2014 I am looking at PUBLISH as we speak, i think this should work for what I require. Thanks for your help guys Quote
VVA Posted June 3, 2014 Posted June 3, 2014 Print Conductor - Professional Batch Printing Software 2Printer is a command line tool for printing documents and image files in batch mode Universal Document Converter - Automatic Conversion from AutoCAD to PDF Quote
BIGAL Posted June 3, 2014 Posted June 3, 2014 If all your dwgs are set up for layouts then using a script will do all. Only prob is individual pdf's http://www.cadtutor.net/forum/showthread.php?67793-script-to-plot-all-(named)views/page2&highlight=views script open dwg1 (load "plotpdf") close N open dwg2 (load "plotpdf") close N open dwg3 (load "plotpdf") close N Quote
RobDraw Posted June 3, 2014 Posted June 3, 2014 No external program is needed. AutoCAD can produce the PDFs and you can batch plot using PUBLISH. Hopefully the layouts are all set-up correctly. If not there is a way to import a page set-up from within publisher. Quote
LibertyOne Posted June 3, 2014 Posted June 3, 2014 Hi Guys, We have been supplied over 150 dwg files and I have been assigned the task of exporting them all to PDF. Is there a batch processor that is capable of doing this task? I can see software that will cost $99 and hopefully be able to do it, but im hoping to learn how to do it some other way (if possible!) Has anyone been down this path before and been able to do it? Thanks Man, that type of job sucks -- soon as I get home I'll post some code that someone could possibly change to work with your situation... Quote
LibertyOne Posted June 3, 2014 Posted June 3, 2014 Oooooo....just looked into my code...and it's a bit complicated because the code was meant to place a plot stamp on a drawing in model space where the drawing border and title block were scaled up to a certain size to match the scale of the drawing in model space. None of the drawings were in paper space. Each drawing was read and it knew which sheet size (A4, A3. A2, A1, A0), where the border was positioned and what scale it had. It then entered the stamp and then plotted to pdf. We had about 450 drawings and divided them out between the three of us. While the other two guys were doing everything manually, I set out to write a program to do it automatically. I finished it in about a half hour and had my 150 drawings plotted in pdf about 20 minutes later. Of course I shared this with the other guys, and they had their drawings finished two hours ahead of what they would have done manually. So I post the code for you all to pick at: SCRIPT: filedia 1 -PLOT J Model DWG To PDF.pc3 !md_blatt Millimeter Querformat Nein F !md_fen_ul !md_fen_or Anpassen Zentrum Ja Plot_SW_Fert03.ctb Ja W !md_file Nein Ja Ja LISP CODE: (I've changed some names around to keep identities secret) ;;STAMP.LSP ;;Adds documentation stamp and stamp number to the drawing. (defun C:STAMP ( / ) (setq md_filedia (getvar "filedia")) (setq md_attdia (getvar "attdia")) (setvar "filedia" 0) (setvar "attdia" 0) ;;------------------------------- ;; add stamp ;;------------------------------- (setq en(car(entsel))) (setq elist(entget en)) (setq md_sf (cdr (assoc 41 elist))) (setq md_tb_ul (list -180.0 80.0 0.0)) (setq md_ul_xyz (mapcar '(lambda (a) (* a md_sf)) md_tb_ul)) (setq md_xyz (mapcar '+ md_ul_xyz (cdr (assoc 10 elist)))) ;path of stamp (setq md_path "C:\\Dokumente und Einstellungen\\John.Doe\\Eigene Dateien\\Doku\\stamp.dwg") (setq stamp-nr (strcat (substr (getvar "dwgname") 1 12) "/" (substr (getvar "dwgname") 14 3))) (setq md_file (strcat (substr (getvar "dwgname") 1 23))) (command "_.-insert" md_path md_xyz md_sf "" "" stamp-nr "") (command "_regen") (command "_purge" "_a" "*" "_n") (command "_purge" "_a" "*" "_n") (command "_purge" "_a" "*" "_n") (command _"zoom" "_e") (setvar "filedia" md_filedia) (setvar "attdia" md_attdia) ;;------------------------------- ;; print ;;------------------------------- (setq en(car(entsel))) (setq elist(entget en)) (cond ( (= (cdr (assoc 2 elist)) "RAHMENA0_L4") (setq md_border_or '(2329.0 841.0 0.0) md_blatt "ISO A0 (841.00 x 1189.00 mm)") ) ( (= (cdr (assoc 2 elist)) "RAHMENA0_L3") (setq md_border_or '(1949.0 841.0 0.0) md_blatt "ISO A0 (841.00 x 1189.00 mm)") ) ( (= (cdr (assoc 2 elist)) "RAHMENA0_L2") (setq md_border_or '(1569.0 841.0 0.0) md_blatt "ISO A0 (841.00 x 1189.00 mm)") ) ( (= (cdr (assoc 2 elist)) "RAHMENA0_L1") (setq md_border_or '(1379.0 841.0 0.0) md_blatt "ISO A0 (841.00 x 1189.00 mm)") ) ( (= (cdr (assoc 2 elist)) "RAHMENA0") (setq md_border_or '(1189.0 841.0 0.0) md_blatt "ISO A0 (841.00 x 1189.00 mm)") ) ( (= (cdr (assoc 2 elist)) "RAHMENA1") (setq md_border_or '(841.0 594.0 0.0) md_blatt "ISO A1 (594.00 x 841.00 mm)") ) ( (= (cdr (assoc 2 elist)) "RAHMENA2") (setq md_border_or '(594.0 420.0 0.0) md_blatt "ISO A2 (420.00 x 594.00 mm)") ) ( (= (cdr (assoc 2 elist)) "RAHMENA3") (setq md_border_or '(420.0 297.0 0.0) md_blatt "ISO A3 (297.00 x 420.00 mm)") ) ( (= (cdr (assoc 2 elist)) "RAHMENA4") (setq md_border_or '(210.0 297.0 0.0) md_blatt "ISO A4 (297.00 x 210.00 mm)") ) ; (= T (princ "Kein Rahmen")) ) (setq md_border_sf (mapcar '(lambda (a) (* a md_sf)) md_border_or)) (setq md_fen_ul (cdr (assoc 10 elist))) (setq md_fen_or (mapcar '+ md_border_sf (cdr (assoc 10 elist)))) ) For all this to work, I created three files. STAMP.DWG (which was inserted as a block into each drawing) STAMP.LSP (the lisp file listed above) STAMP.SCR (the script file listed above) The drawing borders and title blocks were company standard files and the plot PC3 plus the CTB used for plotting. Have fun picking at it... Quote
BIGAL Posted June 4, 2014 Posted June 4, 2014 soon as I get home I'll post some code Liberty one did you look at my post and the link ? Ben_Vk its your turn now have we been helpfull before we all run away posting code as we are guessing what you want to do next. Quote
BIGAL Posted June 4, 2014 Posted June 4, 2014 Moderator this is posted twice http://www.cadtutor.net/forum/showthread.php?86752-How-do-i-batch-convert-150-dwg-to-pdf Quote
Tiger Posted June 4, 2014 Posted June 4, 2014 I have merged your two threads into one, please don't post the same question in multiple forums. Quote
