NoroZorro Posted May 31, 2014 Posted May 31, 2014 Please advise me on how to accomplish this action. See picture. Dwg Attached. As I'm stretching the polygone i want the original cirlce to take a shape of red circle.Thanks Drawing2.dwg Quote
dbroada Posted May 31, 2014 Posted May 31, 2014 I'm not at my CAD machine until Tuesday but I think I would look into using constraints (I am sure 2013 has them). I would constrain the circle to the mid point of the rectangle and constrain its diameter to the rectangle's width. Quote
NoroZorro Posted May 31, 2014 Author Posted May 31, 2014 thanks for the quick response, to set each of the constraints below requires one command or i need to do preparatory work...Book me on tuesday but i'm impatient:( thanks again constrain the circle to the mid pointrectangle and constrain its diameter to the rectangle's width Quote
dbroada Posted May 31, 2014 Posted May 31, 2014 you need to look in to geometric constrains. I think that is on a tab in the bedit palette. Quote
NoroZorro Posted May 31, 2014 Author Posted May 31, 2014 dbroada here are the constraints, can you break it down for me please i looked at every parameter no success Quote
