I'm following a max tut that I saved as pdf and Im practicing with same type of model in the tut - a cup of coffee (in my case cup of tea)'
ok, here's my problem: I'm trying to add the jpg image to the cylinder (the liquid hot tea w/ milk added) so I can go to next step in this tut (uv map, etc)
even tho I know how add jpg's as background images (for that jail I started to make about a year ago) to the view port I don't know how to add them to subobjects (this cylinder/liquid hot tea object) - how do I do this?
see screenshots, (my practice model, part of tut I'm having difficulty with, & my jpg of hot tea)
thanks in advance
If the coffee cup and cylinder are all one object, you will need to create material id's for each object and use a multi/sub-object material to apply different materials to each object.
Tutorial:
  • 1 month later...
thanks, i'm d/l the youtube video that you linked me to now.
  • 1 year later...
