None of the created elements are visible in Floor Plan
I'm placing interior elevation symbols on the first floor level and I keep getting the following message.
None of the created elements are visible in Floor Plan: First Floor View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings.
They show up on the level "bottom of footing"
The View Range Settings
Top: Associated Level (Frist Floor) Offset 7'6"
Cut Plane: Associated Level (Frist Floor) Offset 4'0""
Bottom: Associated Level (Frist Floor) Offset 0'0"
View Depth Level: Associated Level (Frist Floor) Offset 0'0"
Any Suggestions?
I figured it out.
I had the Elevation symbol Category hidden on that level.
Where is the "Freeze in Current Viewport" setting when you need it?
you could different hiding/isolating with the sunglasses in the tab panel (where the detail level etc is)
not quite the same but comes in very handy.
I found them by clicking on the light bulb to reveal hidden Elements.
  • 2 months later...
I'm wondering if there is any way to get the plans for these houses, maybe they are held at a city planning office or something? Also, if we know the builder of the home, would it be possible to contact them and request a floor plan?
integrityluxuryhomes . com/plans . php
