Hello,
I am trying to generate a cube filled with thousands of spheres with different size, then I want to combine all spheres, I want to program generation of such an explained medium. is it possible ? Can I find a user guide for Inventor's VBA to generate that through the program automatically?
thank you
Doesn't matter which programing language you intend to use, if you have random spheres of different sizes in a cube the maths will be mind boggling, unless you have some mathmatical formula doubt you will get any answers.
If spheres are same size for a given cube then easy just copy array etc. Not sure about joining together to be one object.
