I look for a routine that will resolve the following task:
1 - I select a group of text entities (in this case numbers)
2 - Then I draw a point near the position of one
3 - Finally, the routine must be able to replicate the point in the other text strings, maintaining the same close relationship defined in step 2
Attached a drawing to better understand
Tanks for help!
cadtutor_test_points.dwgFetching info...
Try this
(defun c:txtpt (/ txt1 txtpt pt ss i ptsz ang dist ip pt1 pt2 pt3 pt4)
 (setq    txt1  (progn (princ "Pick First M/Text Object")
            (ssget "_+.:E:S" '((0 . "*TEXT")))
   txtpt (cdr (assoc 10 (entget (ssname txt1 0))))
   pt    (getpoint txtpt "\nSelect loction of point")
   ss    (progn (princ "Select All M/Text Objects")
            (ssget '((0 . "*TEXT")))
   i     0
   ptsz  (getreal "\nHow large should the point be?")
   ang
         (angle txtpt pt)
   dist
         (distance txtpt pt)
 (while (< i (sslength ss))
   (setq ip  (polar
       (cdr (assoc 10 (entget (ssname ss i))))
       ang
       dist
     pt1 (polar ip (/ pi 2) (/ ptsz 2))
     pt2 (polar ip (* pi 1.5) (/ ptsz 2))
     pt3 (polar ip 0 (/ ptsz 2))
     pt4 (polar ip pi (/ ptsz 2))
   (command "line" pt1 pt2 "")
   (command "line" pt3 pt4 "")
   (command "circle" ip (/ ptsz 4))
   (setq i (1+ i))
That's it. However, it is not necessary to draw the symbol as in my example. My intention was that it be interpreted as a point. I just want to be drawn to simple point entity.
I appreciate the update.
Edited by teknomatika
I think this way solves what I want.
(defun c:txtpt (/ txt1 txtpt pt ss i ptsz ang dist ip)
   i     0
   ang
         (angle txtpt pt)
   dist
         (distance txtpt pt)
   (setq ip  (polar
       ang
       dist
   (command "point" ip)
   (setq i (1+ i))
Try ..
(defun c:Test (/ *error* c s n sn e aa ab ac)
 ;;    Tharwat 23.05.2014        ;;
 (defun *error* (msg)
   (command "_.ucs" "_w")
   (if c (setvar 'cmdecho c))
   (if (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*")
     (princ msg)
     (princ (strcat "Error : < ** " msg " ** >"))
 (if (zerop (getvar 'PDMODE))
   (setvar 'PDMODE 34)
 (setq c (getvar 'cmdecho))
 (setvar 'cmdecho 0)
 (if (setq s (ssget '((0 . "TEXT"))))
   (repeat (setq n (sslength s))
     (setq sn (ssname s (setq n (1- n))))
     (setq e (textbox (list
                        (cons -1 sn)
     (command "_.ucs" "Object" sn)
     (setq aa (car e)
           ab (cadr e)
           ac (list (car ab) (cadr aa))
     (command "_.point"
              "_non"
              (list (car ac)
                    (- (cadr ac) (/ (cdr (assoc 40 (entget sn))) 2.))
 (setvar 'cmdecho c)
Tharwat,
tanks!
I appreciate the work. As always, perfect.
It is an interesting option and that also solves my need.
However, I prefer the solution already presented in this thread, because it allows the set point position for each text string.
The location of the point shown in the drawing that I have attached, is just one example.
The main idea is that the position of the point relative to the text string can be pre-defined.
  teknomatika said:
Tharwat,
tanks!
Happy to hear that . :)
Not a problem , I just wanted to make life easier as best as I can . ;)
Good luck .
Here is another way to approach the task:
[color=GREEN];; Text Point  -  Lee Mac[/color]
[color=GREEN];; Prompts the user to specify the location of a point relative to a single text object[/color]
[color=GREEN];; and generates a point in the same location relative to every text object in a selection.[/color]
([color=BLUE]defun[/color] c:txp ( [color=BLUE]/[/color] ang ent enx idx ocs sel vec )
   ([color=BLUE]while[/color]
       ([color=BLUE]progn[/color] ([color=BLUE]setvar[/color] 'errno 0)
           ([color=BLUE]setq[/color] ent ([color=BLUE]car[/color] ([color=BLUE]entsel[/color] [color=MAROON]"\nSelect source text object: "[/color])))
           ([color=BLUE]cond[/color]
               (   ([color=BLUE]=[/color] 7 ([color=BLUE]getvar[/color] 'errno))
                   ([color=BLUE]princ[/color] [color=MAROON]"\nMissed, try again."[/color])
               (   ([color=BLUE]null[/color] ent) [color=BLUE]nil[/color])
               (   ([color=BLUE]/=[/color] [color=MAROON]"TEXT"[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 0 ([color=BLUE]entget[/color] ent))))
                   ([color=BLUE]princ[/color] [color=MAROON]"\nSelected object is not a text object."[/color])
   ([color=BLUE]if[/color] ([color=BLUE]and[/color] ([color=BLUE]=[/color] 'ename ([color=BLUE]type[/color] ent))
            ([color=BLUE]setq[/color] vec ([color=BLUE]getpoint[/color] [color=MAROON]"\nSpecify point: "[/color]))
            ([color=BLUE]setq[/color] sel ([color=BLUE]ssget[/color] '((0 . [color=MAROON]"TEXT"[/color]))))
               enx ([color=BLUE]entget[/color] ent)
               ang ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 050 enx))
               ocs ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 210 enx))
               vec
               (mxv
                   (mxm
                       ([color=BLUE]list[/color]
                           ([color=BLUE]list[/color] ([color=BLUE]/[/color] 1.0 (([color=BLUE]lambda[/color] ( box ) ([color=BLUE]-[/color] ([color=BLUE]caadr[/color] box) ([color=BLUE]caar[/color] box))) ([color=BLUE]textbox[/color] enx))) 0.0 0.0)
                           ([color=BLUE]list[/color] 0.0 ([color=BLUE]/[/color] 1.0 ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 040 enx))) 0.0)
                          '(0.0 0.0 1.0)
                       (mxm
                               ([color=BLUE]list[/color] ([color=BLUE]cos[/color] ang)     ([color=BLUE]sin[/color] ang) 0.0)
                               ([color=BLUE]list[/color] ([color=BLUE]-[/color] ([color=BLUE]sin[/color] ang)) ([color=BLUE]cos[/color] ang) 0.0)
                              '(0.0 0.0 1.0)
                           ([color=BLUE]mapcar[/color] '([color=BLUE]lambda[/color] ( v ) ([color=BLUE]trans[/color] v ocs 0 [color=BLUE]t[/color]))
                                   (1.0 0.0 0.0)
                                   (0.0 1.0 0.0)
                                   (0.0 0.0 1.0)
                   ([color=BLUE]mapcar[/color] '[color=BLUE]-[/color] ([color=BLUE]trans[/color] vec 1 0) ([color=BLUE]trans[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 10 enx)) ent 0))
           ([color=BLUE]repeat[/color] ([color=BLUE]setq[/color] idx ([color=BLUE]sslength[/color] sel))
               ([color=BLUE]setq[/color] enx ([color=BLUE]entget[/color] ([color=BLUE]ssname[/color] sel ([color=BLUE]setq[/color] idx ([color=BLUE]1-[/color] idx))))
               ([color=BLUE]entmake[/color]
                      '(0 . [color=MAROON]"POINT"[/color])
                       ([color=BLUE]cons[/color] 10
                           ([color=BLUE]mapcar[/color] '[color=BLUE]+[/color] ([color=BLUE]trans[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 10 enx)) ocs 0)
                               (mxv
                                   (mxm
                                       ([color=BLUE]mapcar[/color] '([color=BLUE]lambda[/color] ( v ) ([color=BLUE]trans[/color] v 0 ocs [color=BLUE]t[/color]))
                                               (1.0 0.0 0.0)
                                               (0.0 1.0 0.0)
                                               (0.0 0.0 1.0)
                                       (mxm
                                               ([color=BLUE]list[/color] ([color=BLUE]cos[/color] ang) ([color=BLUE]-[/color] ([color=BLUE]sin[/color] ang)) 0.0)
                                               ([color=BLUE]list[/color] ([color=BLUE]sin[/color] ang)    ([color=BLUE]cos[/color] ang)  0.0)
                                              '(0.0 0.0 1.0)
                                               ([color=BLUE]list[/color] (([color=BLUE]lambda[/color] ( box ) ([color=BLUE]-[/color] ([color=BLUE]caadr[/color] box) ([color=BLUE]caar[/color] box))) ([color=BLUE]textbox[/color] enx)) 0.0 0.0)
                                               ([color=BLUE]list[/color] 0.0 ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 040 enx)) 0.0)
                                              '(0.0 0.0 1.0)
                                   vec
   ([color=BLUE]princ[/color])
[color=GREEN];; Matrix Transpose  -  Doug Wilson[/color]
[color=GREEN];; Args: m - nxn matrix[/color]
([color=BLUE]defun[/color] trp ( m )
   ([color=BLUE]apply[/color] '[color=BLUE]mapcar[/color] ([color=BLUE]cons[/color] '[color=BLUE]list[/color] m))
[color=GREEN];; Matrix x Matrix  -  Vladimir Nesterovsky[/color]
[color=GREEN];; Args: m,n - nxn matrices[/color]
([color=BLUE]defun[/color] mxm ( m n )
   (([color=BLUE]lambda[/color] ( a ) ([color=BLUE]mapcar[/color] '([color=BLUE]lambda[/color] ( r ) (mxv a r)) m)) (trp n))
[color=GREEN];; Matrix x Vector  -  Vladimir Nesterovsky[/color]
[color=GREEN];; Args: m - nxn matrix, v - vector in R^n[/color]
([color=BLUE]defun[/color] mxv ( m v )
   ([color=BLUE]mapcar[/color] '([color=BLUE]lambda[/color] ( r ) ([color=BLUE]apply[/color] '[color=BLUE]+[/color] ([color=BLUE]mapcar[/color] '[color=BLUE]*[/color] r v))) m)
The above will account for the varying position, rotation, width, height & orientation of every text object in the selection, and will also perform correctly under all UCS & View settings.
Lee,
Fantastic! Perfect! In fact very versatile.
Thanks for the excellent work.
@ teknomatika
Just a thought , I don't think it's a good idea to quote every reply with all it codes so that would increase the size of the thread and would be boring to scroll too long for every reply .
  teknomatika said:
Lee,
You're very welcome teknomatika, I enjoyed writing this one :)
  Tharwat said:
@ teknomatika
Tharwat, you are right. Sorry for the inconvenience. I'll take it into consideration.
Not a problem at all , and thanks for taking the tip so friendly :)
