DigitPack Posted May 22, 2014 Posted May 22, 2014 Hi everyone, I'm new here So, don't know where to ask this actually and also please bear with my English. I'm using Revit MEP 2014. I couldn't find default Mechanical template. I tried re-install US imperial using add or remove program but no use. I can not find default mechanical template. But all other default templates like electrical, plumbing are available. Please help me to get back mechanical default templates. I hope placing the .rte file in this directory "C:\ProgramData\Autodesk\RME 2014\Templates\US Imperial" manually will solve the problem. Can someone upload "Mechanical-Default.rte" file for 2014 version? Quote
tzframpton Posted May 22, 2014 Posted May 22, 2014 (edited) Edited: Link Removed. Edited September 30, 2014 by tzframpton Quote
DigitPack Posted May 22, 2014 Author Posted May 22, 2014 Thanks. Its working fine. You can delete the file from your Dropbox now. Thanks a lot! Quote
amirhh Posted September 30, 2014 Posted September 30, 2014 hi i want this templates too... would you attach it to your drop box... thanks Quote
Shaymaa Posted January 13, 2015 Posted January 13, 2015 I want the MEP default template too ,, metric ,,,urgently please Quote
tzframpton Posted January 13, 2015 Posted January 13, 2015 The content is downloaded automatically during the install. Re-initiate the install and make sure the content is checked. Quote
hoss Posted February 11, 2015 Posted February 11, 2015 you can always download such templates from autodesk seek Quote
