MillerMG Posted May 19, 2014 Posted May 19, 2014 Our company uses "hand" as the style for all our projects. I need to import a table from excel with excel formatting. After I change all the text to "hand" style I can't figure out how to change the font. Any help would be greatly appreciated!! Quote
ReMark Posted May 20, 2014 Posted May 20, 2014 You could try changing all the fonts in your Excel file to system font then reinsert. Quote
MillerMG Posted May 20, 2014 Author Posted May 20, 2014 I'll give that a try. Currently working on structural designs for a church addition. Thank you. Quote
ILoveMadoka Posted August 16, 2022 Posted August 16, 2022 Dealing with this same type issue.. I have no SYSTEM font listed in my Excel Where is this SYSTEM font? Anyway.. no matter what font I have in Excel, when I Paste Special -> Autocad Entities (do not want a link) I cannot globally change the font, I've changed the table style, change the table style font and the only option is to change them one cell at a time. I know about Stripmtext (which works) but I have people in my dept who cannot use routines and so I am looking for a way to be able to bring in a non-linked table and have the fonts changeable. Even Match Cell doesn't work. It works is a sprinkling of cells but it not consistent. Please advise Quote
BIGAL Posted August 21, 2022 Posted August 21, 2022 (edited) I am testing make a Acad table form a open excel but you run it as a lisp. Should b eable to add option about text style as it only reads the cell text value non of the other stuff. Watch this space Edited August 21, 2022 by BIGAL Quote
ILoveMadoka Posted August 25, 2022 Posted August 25, 2022 I found a multi-step workaround procedure. BIGAL's process sounds awesome when he rolls it out... Quote
BIGAL Posted August 26, 2022 Posted August 26, 2022 (edited) Post a sample excel to test. Just need to wade through these options and find correct one to set text font. So please if want more than font ask now. The command you want is (vla-setCellTextStyle obj row column textstyle) looping through the table cells. list of methods for a table.txt (defun settabsty ( / obj styname x y rows column) (setq obj (vlax-ename->vla-object (car (entsel "Pick table object")))) (setq styname (getstring "\nEnter text style")) (setq columns (vlax-get-property obj 'Columns)) (setq rows (vlax-get-property obj 'rows)) (setq x 0 y 0) (repeat rows (repeat columns (vla-setCellTextStyle obj x y styname) (setq y (1+ y)) ) (setq y 0) (setq x (1+ x)) ) (princ) ) (settabsty) Edited August 27, 2022 by BIGAL Quote
